Builds Fly By Night (10 Viewers)
So the idea from here was to pile a bunch of weight on top of the frame to mimic the full weight and check shackle angles, diff angles, and castor.
A fully dressed tub with interior would be what, 2,000 lbs? A 2F is about 750, but the LS is somewhere around 500 - 550. NV4500 with split case is probably around 250. Front bumper with winch - 200?
Rear bumper with tire, jerry can, high-lift? 350?
Front clip with hood - 200?
3,500 - 4,000 would you say?
How the heck to pile 4,000 lbs on a frame? Cover it with plywood and dump a few loader buckets of dirt?🤷🏻‍♂️
This might be a pain[/QUOTE
Fat HOOKERS 👄👄🐷🐖🤯🤫😳🙄🤨😎😒😉
Did you take pictures before you gave them away?
Yes I did....
So, keeping with the random content of my posts from the last month or so, here’s this...
Spent a good portion of last weekend working on organizing my dungeon parts horde (when I wasn’t going back and forth with the Sty, mounting axles, or working on the back door of the house).This popped up - the upper core-support cross piece that has the hood latch bolted to it. I recalled someone recently dealing with the mysterious factory open-air shim engineering on the later models, and how the bolts distort the cross piece because there’s no substantial backing for the bolt head. Without even realizing it, mine is the same way. Something else I didn’t realize was that I have another cross piece that doesn’t have the badly engineered amendments. It came from the last of the 1971 overseas, right-hand drive FJ55 whose remnants I picked up back in April of 2019. Kinda cool! I can just shim it with something solid like they should have done, and call it good!
The sandblasted pieces are my original hardware.
Mine looks like your 71 because mine is a 71, too. In the end I welded a couple of 90 degree braces to the front to help hold it straight . If that makes sense. I can't find any pictures right now, but if interested will take some tomorrow. Just about everyone I've seen has both sides bent down from slamming the hood, the braces help hold that up along with the rod support.
Why do I keep thinking you were the one that had the distorted bolt holes on that piece? Makes no sense - musta been someone you were helping. Some of this stuff is starting to run together. Must be getting old.
