Box Rocket
Then just buy the parts you can afford and hang onto them until you've got the rest of the parts, then install them all together.I'm trying to do it a little at a time because of money.
Any Up-dates ?? More Pic's ??
Just resize the photos in any free photo editing software.I have a ton more pics but I can't get them to upload to the sight. My wife's Nikon is good for about 3-6mb per image and I guess they are just too big to load here. I have been meaning to do a pt 2 review since I finished my last trip, but, the photo thing is a real holdup !
Is there a write up for how to paint those wheels?A couple of shots for those that want to see the stance of it. This is ride height with my normal load out. For trips there would be an additional 400-600lbs of gear towards the back. I will have pictures of that soon. View attachment 1423209 View attachment 1423210 View attachment 1423211 View attachment 1423212 View attachment 1423213
Welcome to the cool kids club !!! Your going to enjoy them.I just finalized my order for 4" flexy fronts and 6" shocks with Dave Otero. Looking forward to being one of the cool kids.![]()
No but if you PM me I can give you a pretty easy run down and get you on your way.Is there a write up for how to paint those wheels?
We've never met, so you don't know, but i'm somewhat computer challenged. Don't get me wrong, I can search just about anything, but i'm not great when it comes to running programs. Definitely want to figure this out though as its a real hiccup in my game.
They only way we were able to do this long term successfully was to taper the wire, and ensure they came off the mandrel in spec and could not be retempered to meet spec if outside it once they had been scragged. [those that dont make spec go to scrap]
Otherwise with all the testing we dd with Aus grade materials we saw breakages right where the active to dead coils flex, and/or sagging within months.
We went through 9 designs to get that right. We have coils from 2002 still going strong in these designs with tapered wire.
Not saying these will do that, but just i my experience what I have found with dual/progressive/linear coils.
In any case, this is why this type of coil design is not suited all that well for people who add a ton of static weight with expedition stuff. You simply lose that little progressive sweet spot across a load profile and you should spend your money on shocks.
In regards to the transition zone being failure prone in a dual rate progressive design, I don't know that we have a good population study - we would probably need to look outside of the 80 series population.
Im sure you are referring to the OME stock height replacement springs 861/862 that are dual rate with same size wire all the way through all the turns correct?The flip side to that is you can run a dual rate front where you know your loads aren't really changing and a linear HD rear setup if you really are carrying that much constant weight. I know there are some guys on here that carry 600+ lbs full time in the back of there rigs. Some quite a bit more if they have a trailer. For my purposes the vehicle must be able to transition back and forth from daily driver and very little extra weight, to camping rig with additional 400-600 lbs.
As for a failure prone transition zone, I wouldn't mind hearing from all the guys running the OME dual rates for the last 15 years. I could definitely see if you didn't get the heat treat right. In fact I could see how one bad batch of springs would give people that exact impression. My 94 has had them for 6+ years and they were used when I bought them. I haven't noticed any issue other than they are a bit rough on an unloaded rig. They still have space between the ride rate coils.
