You will definitely need longer shocks to run the slinky or Dobinson progressive/dual rate spring because they have a taller free height and, therefor, collapse further under the static load of the vehicle. So, you end up with more down travel in a spring that provides the same lift as a linear rate spring along with a more supple on the road ride.So, lots of good intel, but I could still use some advice. I am lifting my 92 FJ80 and can only go a few inches before I hit the the roof on the garage door (yes, it is short). I purchased a set of King OEM Performance Series shocks (0-2") and was hoping to purchase some Slinky's but have been told that the shocks need to be longer in order to use the 50mm longer Slinky's. I dont really understand but am looking for the best springs to put on it, straight rate, dual rate, or progressive; and the most recommended manufacturer.
The truck is my DD and used on weekends in the Sierra's, fun things, but not a hard case rock crawler. Still working on the final unloaded weight (the front will have a small bumper and Warn Zeon 10S on it and not sure if and when I'll get a bumper for the rear) and will probably carry 600 extra pounds when out and about
So, and yes I have searched, what are peoples thoughts? I added this to this section because an definitely considering the Dobinson's.
Thanks!
Here's my thoughts on ICON vs KING shocks. Both are top quality manufacturers and from my experience have similar durability, and if rebuilding is needed it's about the same process for either one. All that being said, I'm a big proponent of using components that are designed to work together. For instance, the custom spec ICON shocks that are part of the Slinky kits are designed and tuned specifically to give the best performance with those coils on a specific vehicle. Not a "universal" happy medium that will work but not give the best results. I use the Slinky as just an example. The same principle applies to whatever brand of components. There may be exceptions but in general I believe that components that are part of a complete suspension "system" will be better.Thanks for the quick reply, much appreciated. So, if longer shocks are required, then there are three questions.
1) If I keep the 2" Kings, what spring manufacturer is the most recommended for a straight rate?
2) How do Icon shocks compare with Kings with respect to durability, rebuildability, and staying in business for a long time
3) Is there enough value in the Slinky or Dobinson's coils to have my Kings lengthened or change to the Icons
I definitely do searches, but a search for "replacement coil springs" as an example comes up with 43 pages of posts, each with multiple pages of posts, many of which are full of little relevant direct information to the search (because if any of those three words show up anywhere in the page it is linked back to the search, relevant or not), rants, arguments, and off topic commentary. As a result many searches become tiring, inefficient, and confusing. Sorry to all the search police for that, but it is true, at least for me
Hey @half k cruiser how about a review/summary of your thoughts now, since you had all spring (pun) and most of the summer running these?
@half k cruiser Nice trip indeed. I can't wait to head out on mine next month.
Do you normally have some stinkbug when unloaded?
I'm currently running Slee 4" progressive heavies in the rear but I'm very curious about trying a set if the Dobinson 4" progressives. Can you estimate how much weight you typically load for a trip like the one you posted?
So here's my thoughts of the Dobinsons springs after that trip....
Pro's
- they make a surprising difference in ride quality off-road
- they don't bang around like the OME setup I had before
- they still have potential to grow, the limiting factor here is my current shocks and whatever is binding the front suspension
Con's
- with the weight I had in it the truck developed a very slight rake to rear. It does not do this when my camping gear is out. If you are pulling a trailer or a camper you could easily compensate with shims or air bags. Note they are designed for 100kg over, and I was definitely putting more than that in the truck.
- they take getting used to in corners. They will have more give initially on cornering than a linear rate spring. Once you get into the load rate
they firm up and all is well. The bigger factor here is shocks.
Overall I am completely happy with my purchase. The springs made a substantial difference in off road ride quality and I feel they are an excellent value considering their going rate from Dobinsons USA. I also like that there is still a lot of potential left in the suspension. The biggest limiting factor right now is the shocks. I really think to get the most out of the 80 is going to require a jump to 2.5's , preferably with reservoirs and CDC adjusters. I know that Dobinsons currently has a reservoir shock in the MRR line that can be paired to these coils.
thx for your review, I am considering going with the 4 inch progressives from trail gear eventually.
For me my on road driveability is as important as off road. Do you feel like your on road driveability has suffered after going from a linear to a progressive spring? Are you running stock swaybars? I am guessing the stock sway bars should minimize any increased roll from the new springs.
Looking at your photos is like having an ultimate off-road dream!! Really awesome photos. And a great review too.
