Green Bean
My advice: Buy twice as much as you think that you need. It is nice to have extra on hand for when you need it.
Nicely done. Only problem is-it doesn’t absorb oil like cardboard….View attachment 3741152
My garage white board. Left is a shopping list for the 40, right is a task list for the 75.
Had to laugh when I read this. Reminds me of my time in project management .Well I can't believe we are talking about list making but OK fine.
Here's what I do:
It sounds like a lot when I jot all it down but these are just habits from my old life managing projects at work.
- I have a small whiteboard in the garage and I add tasks to it for current in-progress projects
- I have a notebook where I design things (wiring harnesses, sketches of custom parts, etc)
- I have a spreadsheet of parts I want to track down.
- I photograph every project I start and keep folders on my PC so I can resume projects without forgetting what I did
I am just glad that the steering committee (me) doesn't expect the project manager (me) to create powerpoint status updates. And the review board (me) isn't asking the system architect (me) to submit my designs as visio files. And for the love of gawd I will not raise a ticket to the technician (me) just to get a bolt tightened so don't even ask!
My only quibble is the Saginaw box being cleaner. I think the placement of the 60/80 box is much less invasive. The sag box requires cutting (structural ) the crossmember and a mounting plate. Th lc box only requires a mounting plate and similar mounting holes. I suppose the fender sport needs to be modified, but it’s minor compared to the hole in the xmember.OK it's almost wrenching season so I am gathering parts and making decisions.
My goal is a crusty patina driver that straddles the line between 3-week trips to Baja and getting through the Rubicon (in a group). Sprung over on 35s, power steering, 5 speed, and as a stretch goal, some kinda diesel.
I'm close to pulling the trigger on a few things so last chance to talk me out of it.
Seem reasonable?
- 70 axles, cut & turned - easy swap, stock width, good ebrake, full floating rear, share parts with my Troopy. SOA.
- Saginaw power steering - this offends the Toyota purist in me but the box seems to be a cleaner fit than a 60/70/80 steering box
Not necessarily. Saginaw box with a forward-facing Pitman is pretty clean...The sag box requires cutting (structural ) the crossmember and a mounting plate.
Seem reasonable?
Unless you have some sort of really good deal on 70 series axles I would go with 60 series axles for the extra width.
They will still share 90% of parts with your troopy but in practice I have found sharing parts between vehicles to not be a worthwhile goal
I'm not purist but I am a much bigger fan of 60/80 box vs saginaw for 37 or smaller tires on a 40, I feel saginaw is a bit "too much" box and usually too numb, just my opinion.
you already have a massive project
so personally I would start with a F/2F and some sort of H42 to get the ball rolling as it will all bolt in and be super simple. Do your suspension/steering/electrical and drive it for a year or two and make sure you actually like it before investing in an expensive engine swap.
That's a pretty sharp rig - it's most of what I have in mind.We built a similar truck in my shop this year and it easily cruises highways speeds and Rubicon would be a cakewalk with it
I don't think I am after a wider stance. I think from rigs I've looked at, SOA on 35s is OK on stock width axles.
Yeah my gut feeling is I'd rather have a Toyota 60/70/80 box but its not yet clear to me how I'd set up the steer linkage with the SOA. I'm still looking for a good example online or in person. Failing that I'll let my buddy do what he's good at (Saginaw).
wait a minute... did Cruiser "OEM" Matt say "I'm no purist?"
You're thinking of the wrong Matt....wait a minute... did Cruiser "OEM" Matt say "I'm no purist?"
Sorry, sorry... my bad! Got you guys mixed up. You're both great. Not enough coffee and too much nog.Is this news? I have an entire catalogue of GM conversion parts for 60’s and 80’s I’ve developed. Maybe you’re mixing me up with the other Matt.
Even with a SOA as low as possible you'll end up wanting the width. FJ40's originally came with 28" tires - so you are getting roughly 3" of lift from just the 35" tire alone.
we just used an off-the-shelf high-steer kit for a 60, and a flat pitman arm.
I make all the parts to put the box on the struck, frame plate, column, radiator support notch etc
what extra work is there? You probably don't realize putting 60 series axles in is going to be pretty much the exact same amount of work as putting 70 series axles in? Either way you have to move perches on both sets of axles, and if you are doing a SOA it's moot anyways because to do the SOA correctly you are going to be cutting everything off and moving it all anyways.I get the logic here but I've driven a few SOA 40s on stock width axles and it wasn't terrible. In the end it comes down to cost and effort. I get the benefit but not sure that's where I want to put the effort (to adapt to wider axles).
I'll send you a PM. I was just poking around your site looking for info on this setup.
I could fab this all up with help from friends but parts that cut down on fab effort would be great.
I don't take any offense. This is my first short wheelbase rig and first time I've considered an SOA conversion. All I know is what I've read on mud and the varied opinions of friends and colleagues and mudders.This question isn't meant as a dig, but have you done a SOA before?
That all makes sense.Either way you need high steer and linkages, spring perches on both axles, cut and turn, shock mounts, brake lines, shackle reversal depending on how low you want it, etc etc
