You’re re doing the rear brakes on your 69 fj40
That’s interesting. The front cylinder has the adjuster on the top so that means it pushes on the bottom shoe, but is somehow still the ‘top’ cylinder.
Wouldn’t it be simpler to just say front/rear, as they’re oriented on the backing plate?
The return springs are on wrong. One needs to be on the outside. I'm not sure that it matters.
I'm still bleeding the wheel cylinders with PTFE tape on the threads of the bleeder screws. The bleeder tube is oriented like a plumbing trap in opposite, with an air bubble set in a loop of bleeder tube, at an elevation above the wheel cylinder. The idea behind this is that the system has can let gravity sort-out the bubbles at the level of the wheel cylinder. Because the PTFE is disallowing hydraulic fluid from leaking out the thread interface at the bleeder, it can be opened a bit more to move a greater volume of bubbly fluid. I really don't think that adjusting wheel cylinder shoes is going to help actual bleeding because the wheel cylinder pistons are under spring tension at the brake shoe, they don't need to be pressed against the drum for fluid to escape. It could help to adjust the pistons so they basically don't move during bleeding, but, that is too much work, and for what, to save a few ounces of hydraulic fluid. Really, I can bleed the brakes, in accord with the manual, without all the crawling on the floor for adjuster adjusting, and be confidently on the road within an hour, and I do it every time the reservoirs look even a bit cloudy (twice-a-year).
The front brakes seem to grab. I adjusted the rears out to tight, bled them, then they were no longer tight so I adjusted them again, left some drag, put the wheels back on. I guess it’s just gonna stay two pump.
Small update. Got everything put back together and still had a leak. It looked like the crossover pipe from cylinder to cylinder on the right rear.
Bought a new one, installed it, another leak. This one is in the pipe on top off the diff to the right rear rear cylinder.
So, waiting on that to come in.
I have discovered though that even when I clamp off the rear soft line, there’s still no pedal (when fluid is low), but when I jack up the front, the front brakes work, by trying to spin the wheel by hand anyway. Dual reservoir master cylinder. 🤷🏼‍♂️
After (2) new wheel cylinders and (2) new brake lines, I may actually have brakes. Just need to wait for my kid to get home to help bleed them. Even without bleeding them, they feel better than before, but that might just be wishful thinking.
