FJBen
I know, I was torn putting one in mine. It is stupid handy though. Waze works great and has the built in speedometer.Those apple carplay stereos are so handy, but so wrong in an old 4x4 at the same time
That JVC is a nice unit. I particularly like the fact that it does not have buttons or the USB socket on the front like so many of the other 2-DINs on the market.
Where did you mount the camera?
Before I started smoking cigars in my trucks I mounted the USB's in the ash tray for my 100 series in the US.It does have a USB socket, but it's a dongle that feeds out of the back. I need to find a way to front mount that in one of my switch blanks... so I can use CarPlay more readily. I too like the no buttons... except I do wish it had a rotary knob for quick volume changes. It has a gesture input that works nearly as well as a rotary knob.
Something like this is exactly what I had in mind for one of my switch blanks.Before I started smoking cigars in my trucks I mounted the USB's in the ash tray for my 100 series in the US.
Here is an album of all the photos.
And in an 80 series I did something similar using an extension from Amazon:
The two switches, incidentally, were for forcing the unit to think it was in park and in reverse (red). I did this so I could have a full time rear view from the head unit.
The problem is that I started smoking cigars in my trucks and so the ash tray started to be relevant again. So, sadly, I have no solution to offer you. Just inspiration! When you do your thing I likely will copy it.
I don't know about you but I use Android Auto and it flakes out randomly but seldomly enough that it is useable. I am semi-convinced it is due to the length of the USB cords. I think on my next one I will two two things: cut the cords shorter and carefully solder them to a USB-C socket instead of the USB-A. Ideally something made of metal and much more durable with pins on the back:Something like this is exactly what I had in mind for one of my switch blanks.
I do like my Sportmans Trunks. I'm using the 56 quart versions without wheels. You can stack them. You can sit/stand on them (rib-reinforced lid). They aren't boogie priced like some other "overland" storage. AND they are made in America.That is a highly impressive trip, amount of stuff, scenery and family! Well done. I also note your use of the Plano boxes ("sportsman trunk") on top. I love those things; cheap, durable and with rollers for pulling through airports. They are more than twice as expensive here than at Home Despot in the US.
Unless the panel is defective in some way, you should see 25 years out of a decent panel, (and probably still running 80+% efficiency). From your tests though it is still efficient. And the glass on those is pretty tough, so I would be surprised if it was cracked.While washing the truck several weeks back I noticed some wear/tear on the solar panel. It's been over three years since I installed it up on top of the truck and it is in the sun nearly all the time. The "paper" inside the panel is yellowing... and there are some cracks appearing in the surface (I think they are in the glass, not the actual cells, though I'm uncertain). Anyone have insight on solar panel damage/wear?
I was a little concerned... however, on our trip to CO I was hitting the 90's for my Pmax (maximum wattage generated by the panel). One day even hit 98W... and it's a 100W panel. So still highly efficient and it had no problem keeping up with our refrigeration needs even with many days pretty overcast at times.
I bought a 1000W inverter (not pure-sine-wave) some time back to install in the Troopy. I've just never gotten around to it. It's more of a nice-to-half than a necessity. However, I picked up a 300W Jackery unit for my hunting trip last year and had only used it a few times. For this trip it got extensive use. And it has a pure-sine-wave inverter built into it. I have a handy 12V plug at the back of the Troopy it can plug in to and charge from the solar and/or car battery (solar charge controller handles that). It can charge devices and run the inverter while it's also pulling from the charge controller. And it's portable. I'm no longer going to install the 1000W inverter. The Jackery just provides a superior solution.
The panel is mounted firmly at both ends… which made me a bit concerned about flex in the middle. Those cracks are actually at one end though, not in the middle where there’s any flex. I’ll keep an eye on them.Unless the panel is defective in some way, you should see 25 years out of a decent panel, (and probably still running 80+% efficiency). From your tests though it is still efficient. And the glass on those is pretty tough, so I would be surprised if it was cracked.
That said, I have seen things break in the oddest ways when improper stresses were introduced. IE: were things piled on it (strapped down over it?)
The other thought is when placing these on a surface that may flex could also introduce stresses that are unusual. But from your pic it is hard to tell what those marks might be from.
Say, what monitoring program are you using on your cell phone? I have a charge controller, but it would be nice to get some more stats on everything when testing my multiple appliances.
Put a small piece of polished aluminum on the top-furthest-rear-part of the light to reflect the light down to see the hitch/bumperHere's where I mounted mine. It's the only place I could think of, but I can't get an angle down enough to see the hitch or rear bumper.View attachment 3377324
While I'm in there...Wow, that looks awesome! Hope y’all had fun.
Leaky pinion seal? Gonna add a locker “while you’re in there”?
Happy Holidays!
