I say yes go for it.OK while I'm waiting for the 3rd member parts to arrive had to find something else to keep me busy so I pulled the old rear seals and bearings. Went to the local Autozone and rented the bearing puller, they give a 90 day window to return the tools so I'll put these tools to good use for the front axle as well.
The bearing removed within 4 pulls of the slide hammer
The old bearings didn't look too bad but why take a chance, since the diff is all apart replace all.
I'm also thinking of going all out and installing disc brakes, what do y'all think?
i took it for a 4 hours drive to work on my cabin , after 3 hours the water pump on the 350 start to leak ,i still continued and got to the cabin.
i ordered a new pump in a small town , it took 3 days to get it , so no forest road exploration, it took 2 hours to change it just before going back home.
I highly recommend rear disc..... I love mine!!OK while I'm waiting for the 3rd member parts to arrive had to find something else to keep me busy so I pulled the old rear seals and bearings. Went to the local Autozone and rented the bearing puller, they give a 90 day window to return the tools so I'll put these tools to good use for the front axle as well.
Here's the muffler installed. I can't see any brand identifiers. Cheap house brand I guess. I won't complain about $90 installed though.I need to get rid of the glasspack on mine too (PO installed). Really dislike the sound of it and it also restricts airflow, which I'm not in favor of. What muffler did you use to replace yours?
Drove it! Hit some back roads by my house with my GSP. View attachment 1112384View attachment 1112385View attachment 1112386
Thanks! They start to mellow out around 7. Mines 9 and he's getting to the energy of a normal dog!
New tie rods and tie rod ends, brake check and adjust, de-mud, diff ratio check, new oem wheels and hub caps, new locks and ignition barrel, new oem flasher unit.
So cool getting a stack of boxes from Toyota but I've barely scratched the surface. My truck has no rust but just about every part is completely worn out and in need of replacing.
