What have you done to your Land Cruiser this week? (9 Viewers)
Cleaning, stripping, priming, and painting my '63.
Welded in panels for a '74 my dad owns to make it a panel delivery and figuring out what we want to do for a rear door.
Tripped over the rear axle to my '69.
I am going to polish them a little more and probably wax them or clear coat them. I fear the clear coat will discolor over time so wax might be the best way.
If you can find it, "AutoSol" works awesome. Combined with a buff and a die grinder and you'll be :hillbilly:.
It both cleans and protects. I'd use wax as well.
(Paint stripper will remove clear cote.)
Removed my old tire carrier and sold it off (going to build a dual swing-out bumper). Not much else going on with this crappy weather.
If you were in driving distance I would take you up on those, that one in the picture looks so much better then most of them up here that have not been restored.
Had a look on the map, he looks to be within driving distance for you:hillbilly:. (Too bad there aren't better roads.)
Hop in your 40, and go pick up some parts.;p
X2
Shipping would be the killer. If I was down in Florida, I'd be looking into how to get them from across the Gulf of Mexico.
Across the gulf, maybe I can hire these guys to import a few
Bet they'd work cheap.
worked on
I changed out the optical disk and eye on my distributor installed crane cams eye and disk as well as a ballast resistor and a new crane cams ps20 coil
Fixed the OBA system, unstuck the winch cable, replaced a burned out brake light and fixed a wiper motor issue.
Got a pile behind the shop, Free if you want them, got a troopy body to thats pretty easy to repair,
I tell you what, maybe the next big order that takes place, I may just take you up on that troopy. (to save a little on shipping) Keep me in mind when the time comes. Seriously...
:cheers:
What I have I done this week...
I was busy this week. I replaced, repaired, painted, and cleaned a lot of old and worn parts,
Radiator, thermostat, radiator hoses, heater hoses, fan belts, door weather stripping, passenger side door window, gas tank, rubber fuel lines, battery. I also bought new tires and wheels. I also took out the bench seat and put the jump seats back in.
Ok, maybe not all this week...:D
Hey you,
Agree with Theo, nice truck! Did you have any more info about that storage box behind the front seats please?
Thanks,
I have one just like it; mine is a Con-Ferr locking box that sits just behind the seats. I use it to hold an auxiliary fuse block and tools.
