What have you done to your Land Cruiser this week? (33 Viewers)
Nice job. Would love to see some additional pics on how you are refreshing the wiper motors and the grease you are using etc. My driver side works fine, but the passenger side is like the little engine that *might* could….barely wants to work.
Updates will likely be in its build thread
Do it….
@cims1970fj40 …as I remember correctly, Red Line has the threaded adapter bushing to mount the coolant temperature sending unit on top of the head..which is where mine is on my ‘75 2F…
Read the full page to decide if you may need this…I did. 2F/F Reducing Bushing SNIPER EFI COOLANT TEMPERATURE SENSOR RL1086 (FU1-11) – Red Line Land Cruisers - https://redlinelandcruisers.com/shop/60series/fj60-2f-sniper-kit/2f-f-reducing-bushing-for-sniper-efi-coolant-temperature-sensor/
Just thinking out loud
Was included in the Autometer watertemp gauge package...
It was a rollercoaster of a day, and bittersweet. I took off work, and arrived at Discount Tire as they opened at 8am. The goal was having the new OEM rims and Kenda Klever RT 33x9.5R15 on the truck for the car show at the local Toyota Dealer, along with the OEM hubcaps. So right off the bat, Discount Tire would not mount 9.5 inch tires on 5.5 inch rims. It had to be 6 inch rims according to their computer. Wow. So I ran over to a local shop, Ringo Tire, but they were just covered up with business and couldn't help. So, I check my local Toyota, and they were happy to do it, and did not charge very much, I got out of there with valve stems, tires mounted on the rims and "road force" balanced, and installed on the truck, for just over $100. BUT it died on me on the way over to the dealership. Last time it randomly died I had ash fouling on the plugs, so checking on that came later. But, here are some pictures:
Before (some older pictures):
After (Today):
After I got home, I was going to wire in the 3rd brake light, but I was missing a terminal that I needed, so moved on. There was a brake fluid leak on my new rims at the back right, so I took off the drums, but I did not have a spare for the wheel cylinder that was leaking. So I put it back together and adjusted the wheel cylinders (I may need more practice on that). Next I pulled the spark plugs, but they were not fouled, so now I don't know why it died, maybe a failing pertronix, or maybe that wire that pulled lose from the starter, so that is in my near future to figure out. But anyway, at 4:30 I loaded up to head to the car show. And I must have adjusted the shoes too tight, because about 3 miles down the road it was obvious I was burning DOT3. I pulled over and sure enough, it was smokin! I did not have a good enough screwdriver with me to back off the cylinders, or maybe they were just too hot and seized, IDK. So, I had to limp it home about a mile at a time with stops to let it cool. I've just finished ordering new wheel cylinders online, and after all that I missed the car show. So, that's been my day. Bittersweet like I said, but I do like how the new rims look. Just more fun stuff to do. Ya'll have a great weekend!
I put on the same tires and wheels with hubcaps. I really like them.
Thanks for the looking out. That’s one of the items I bought.
Nothing sucks more than when you’re on a roll in a project and then get stopped completely by not having that odd fitting part. Doesn’t matter if it’s your Sniper install or a garden shed….stopped is stopped!
Almost there, but the heat kept me from the finish line. The header ended up pushing the outlet upward about 2.5", and inward about 2.5" compared to the factory downpipe brace...so I ended up having to make a little S-pipe by cutting and rotating a 45* to make it match up with my tailpipe. I ended up leaving the V-band that I had from my downpipe, but should be a-ok.
Just some minor assembly of the isolator/spacer and reinstalling the Sniper and air cleaner left for the AM, hopefully in some cooler temps.
Definitely had a few pesky leaks from the cast manifold, hoping this is a bit more snug.
I have a magazine from back in the day I think it’s advertising “combo 2” as there “The Man-A-Fre 50 Hp Combo”
Line item 1 combo 2, Rochester carb, Delco dizzy, and 6 into one header = $250.00. Such a deal. Seemed like a good choice to improve performance (at the time).
Took her for the first road test in 25 years up to LOWES and a fill up of some go go juice. Couldn't get out of the parking slot before being stopped by three people who absolutely loved it. Again at the gas station and down the road thumbs and rubber necking!! Crazy attention these things get😳😁
Installed a couple upgrades this week from @65swb45. During our off-roading trip my annoying loose-key fitting ignition switch leveled up to anxiety inducing. I’d get through a rough patch and look down and my keys were gone. Now I’m sweating cause I know I’m going to stall it and be stuck on a hill somewhere.
Second was to replace my Autozone special overflow tank; which would have been fine but it’s like my third one that leaked at the mold line.
I built an extra bracket for the new tank with some bent tabs that allows it to bear up against the radiator and not rotate since it’s on with one bolt.
Yeah Buff, that sage is probably one of the most attractive colors I’ve seen.
That looks great!
Yea I bought that power combo in 1981, the header rusted out in about a year, the dist and carb had probably been rebuilt a dozen times. Pure junk. The only difference I saw was every time I turned left, the engine hiccuped, and on steep climbs gasoline poured out of the carb and it flooded/stalled and died. Other than that it was great LOL !
