Great work, sent you a pm.View attachment 3420176
Installed the headers and manifold. Then set back in her old but refreshed home!
Ordered these and the drain plugs this am. Can’t catch a break at the dealer though. My usual go to guy is out on disability for a bit.From the local Toyota dealer parts counter
I didn’t know this was a required measurement… I bought a new master cylinder and figured …bolt it on and bleed it.Previously my front drum brakes seized unexpectedly. I’ve bought the SST to check the booster / master cylinder alignment.
So. Instead of 0,15 mm, I had minus 5mm (under constant pressure).
After adjustments everything looks correct
Might be helpful to check if you change a master cylinder or a booster.
Fact: what you don’t know CAN hurt you.
Very good note! This is why I put the instruction on the City Racer website. Sometimes people would contact me saying their new brake booster is dragging; I immediately point them to the link. This step is mandatory. It's a very precise spec; you can't just eye it.Previously my front drum brakes seized unexpectedly. I’ve bought the SST (thanks to @Racer65 shop) to check the booster / master cylinder alignment.
So. Instead of 0,6-0,65 mm, I had minus 5mm (under constant pressure).
Don’t we all?Customer has some twisted dreams for this one..........................
Looks like you need to check in here.When you don't have a rotisserie, you gotta improvise...View attachment 3419880
I just flipped mine over (several times) on the ground on carpet and moving blankets. Solo effort.When you don't have a rotisserie, you gotta improvise...View attachment 3419880
are you running a lift at all? I would like to get these tires on my 40 eventually. Just to go back to a more original look.
