What have you done to your Land Cruiser this week? (41 Viewers)
This is kinda piddly but, I changed the rear axle breather hose. I was amazed to find the rubber on the clamp and the bracket to be intact after 41 years……
Drove it about 40 miles this week after being out of commission for the past 4 months.
Big items over the winter included Jim C rebuilding the carb, new brake and clutch master and slave cylinder, soft lines, oil pan gasket, heater box re-foam, heater valve, new hardware and seals for the hardtop and barn doors, rebuilt gauge cluster, acquiring a full tool kit, jack, jack rods and rod holders, acquiring a missing jump seats, and other things I'm forgetting. Long winter, super happy to have it back on the road again.
To all of you who helped me with parts, expertise, or encouragement, thank you!
That OEM radio looks pretty good. How is it holding up for you?
Still works great however it is more for show vs. sound quality. I made this for music instead as a project with my kid last summer. I used my old Coleman cooler from the early 90s and some stereo components I had laying around. It has a 12vdc quick connect so that it can be removed from the truck if required. It is chained/locked to the truck so it doesn't disappear easily. However, locks are for honest people. There is also a tray inside above the radio so that it can used for storage as well.
Sound by Coleman...
Still works great however it is more for show vs. sound quality. I made this for music on the truck as a project with my kid last summer. I used my old Coleman cooler from the early 90s and some stereo components I had laying around. It has a 12vdc quick connect so that can remove it from the truck if required. It is chained/locked to the truck so it doesn't disappear easily. There is also a tray inside above the radio so that it can used for storage as well.
Sound by Coleman...
View attachment 3315412View attachment 3315413View attachment 3315417
That's super cool :cool:
Took the 72 to visit, Colton, our parts guy.
Perfect day for a spring run. Sooner than later, I want to make the trek over and “behold” the 72. I’ll come bearing gifts from “The High Ground”..😎
Got around to replacing my steering wheel cover this morning, here’s to hoping for another 15 years
Also, used new wheel dolly which is a game changer for those of us with bad shoulders.
I use a floor jack to adjust the height to slide a tire on and off. What's harder to do now than when I was younger was mount the spare on the back.
I was given this ten year ago. Haven't had to use it yet but will before long.
Sound by Coleman...
Love this! I need one.
Earlier in the week found no pressure on the brake pedal and discovered the front reservoir had gone dry.
Did the only reasonable thing in response. Fully adjusted the brakes and flushed the lines with a pressure bleeder. Well 3/4 of them. The front left wheel cylinder bleed screws were seized and rounded off. So here's hoping that the short run to those cylinders was ok.
And as a bonus with the truck on jacks, rotated the tires.
The oil spot under the truck is from somewhere on the t-case and has been dripping slowly for ~6 months. Need track that down, but the brakes took priority.
