Did you mix Bourbon with Merlot as 1st gear ratio or 3rd one?I finally went camping with my FJ55. Third time is a charm.
Land between the lakes is amazing in the spring
Lol - just did this last week and was thinking the exact same thing!This kinda piddly but, I changed the rear axle breather hose. I was amazed to find the rubber on the clamp and the bracket to be intact after 41 years……
First Drive after body mounts were replaced. If you have not done this upgrade, I would highly recommend it. Truck seems less harsh but still rides like a tractor.
What have you done to your Land Cruiser this week?
forum.ih8mud.com
Still works great however it is more for show vs. sound quality. I made this for music instead as a project with my kid last summer. I used my old Coleman cooler from the early 90s and some stereo components I had laying around. It has a 12vdc quick connect so that it can be removed from the truck if required. It is chained/locked to the truck so it doesn't disappear easily. However, locks are for honest people. There is also a tray inside above the radio so that it can used for storage as well.That OEM radio looks pretty good. How is it holding up for you?
That's super coolStill works great however it is more for show vs. sound quality. I made this for music on the truck as a project with my kid last summer. I used my old Coleman cooler from the early 90s and some stereo components I had laying around. It has a 12vdc quick connect so that can remove it from the truck if required. It is chained/locked to the truck so it doesn't disappear easily. There is also a tray inside above the radio so that it can used for storage as well.
Sound by Coleman...
View attachment 3315412View attachment 3315413View attachment 3315417
Took the 72 to visit, Colton, our parts guy.
Let’s set it up.Perfect day for a spring run. Sooner than later, I want to make the trek over and “behold” the 72. I’ll come bearing gifts from “The High Ground”..![]()
Also, used new wheel dolly which is a game changer for those of us with bad shoulders.
Love this! I need one.Still works great however it is more for show vs. sound quality. I made this for music instead as a project with my kid last summer. I used my old Coleman cooler from the early 90s and some stereo components I had laying around. It has a 12vdc quick connect so that it can be removed from the truck if required. It is chained/locked to the truck so it doesn't disappear easily. However, locks are for honest people. There is also a tray inside above the radio so that it can used for storage as well.
Sound by Coleman...
When I changed my oil pan and gasket I placed the gasket on a flat surface and then the pan on top. It seemed to conform better on the ends and using the poser method of install my pan is good to go.This weekend it’s a dirty one…Just the usual oil pan and new gasket dance…don’t even ask me what the PO did with the orange PepBoys RTV special…still picking all the orange boogers out of my hair…
Earlier in the week found no pressure on the brake pedal and discovered the front reservoir had gone dry.
Did the only reasonable thing in response. Fully adjusted the brakes and flushed the lines with a pressure bleeder. Well 3/4 of them. The front left wheel cylinder bleed screws were seized and rounded off. So here's hoping that the short run to those cylinders was ok.
And as a bonus with the truck on jacks, rotated the tires.
The oil spot under the truck is from somewhere on the t-case and has been dripping slowly for ~6 months. Need track that down, but the brakes took priority.
