What Did You Do with Your 80 This Weekend? (149 Viewers)
I have 11K miles on my Falken AT4W’s, highway noise hasn’t been an issue. Wet traction in the rain has been good. No experience in the snow with them. My off roading has been limited to chasing trout so nothing extreme. Wear seems to be going good right now.
Everyone seems to like their Falkens. One of the few downsides is the weight, almost 10% heavier than the G3.
But where does that weight show up? I have a 2 inch lift and Im running 285/75-16’s. With cruise control set at 72 (thats 72 on the GPS) I’m getting 13+ mpg on the highway. I haven’t measured them, but if I remember correctly they measure closer to 33” than other similarly sized tires; so is the weight coming from their actual size?
The fact they weigh more than competitors is a bonus. Your probably getting a tire with more meat and more puncture resistance than the competition.
The weight is in a good place un-sprung down low 😜
1991
Replaced the dying seatback nets with these from @plaidwagon . Waterjet aluminum and press braked with some replaceable parachord.
I looked into OEM but for $100 + shipping I figured I might as well look into and upgrade and came across these. The quality, simplicity and longevity are a great addition.
View attachment 3835247View attachment 3835248View attachment 3835249View attachment 3835246
These looks awesome! I really like the 93-94 cloth seats. Thanks for sharing!
Their rubber compound
TFLoffroad recently tested BFG vs Falken vs Firestone in the snow. The Falken A/T4W tested horribly under their test conditions. They were so bad that they reached out to the manufacturer. The Tyre Review on YT also had the A/T4W also performing poorly in the snow, compared to its competition, but not as badly as TFLoffroad shown them to be. Tyre Review had the K02 in their test, and not the newer K03s.
I just recently went with K03s (LT285/75R18) and I am impressed with their snow performance. I was recently trying to activate my ABS on snow to bleed it, and the tires would just grip and stop my LX450, rarely activating the ABS. My Lightning would immediately lock the tires on the same road, activate its ABS and still took much longer to stop. Its tires are just M+S rated and not Three Peak.
TFLoffroad
Tyre Review
I would bet as you cut those zip ties and start pulling out the mess, you'll find maybe 5 or 6 wires that need to be repaired. They always look worse than they really are.
I started undoing that mess zip tie by zip tie yesterday. Once I got the mess straightened out so that I could see what was what, I found the most of the factory wiring is there, just mucked around with. Very fixable.
There is a "black box" that likely contains a remote start, and a motion sensor (a "Clifford" DEI 504c control unit). The trick is going to be fixing the wiring between the connections under the wheel... as most are spliced so that they run through the remote starter...
Started her for the first time in over a month. Sent my front diff back to marlin crawler for warranty repair. They replaced the air line. Got the diff installed with some fresh rotors and pads but after sitting in the cold for over a month she was dead. Scooped up a Noco 10amp battery charger, got her charged up overnight and she fired right up. Was able to test the front locker and thank goodness it works this time! My old compressor isn’t too happy though so need to reseal that because it keeps cycling. Here’s a video of a very cold start and front locker testing.
Hopefully not a quad seal.
Nah it’s not the seal housing o-rings. The compressor cycles the same with or without the locker engaged. I already opened up the compressor once to clean it tighten everything but if you spray it with soapy water you can see bubbles. Might just open it up and slap some rtv on there or get an actual compressor reseal kit. It’s the first generation single arb compressor so it’s tired.
It’s been a long time, but I finally picked up an 80 I plan to keep. My first Land Cruiser was its twin and funny enough this one is coming from about 30 minutes from where I grew up. It will make a great addition next to the 40!
Funny were all different, it was about the only thing I wasn't liking the black wheels.
It's so 70-80s and it just washes out in picturs :meh:
I’ve got a set of clean stock wheels that I’m considering swapping over
It’s been a long time, but I finally picked up an 80 I plan to keep. My first Land Cruiser was its twin and funny enough this one is coming from about 30 minutes from where I grew up. It will make a great addition next to the 40! View attachment 3836840
What you'll look like on OEM's.... ;) 🦀 Now if I could just copy your 40 in my garage!
Hi,
installed the Trailteq kit as well this weekend, super easy to do and completely plug and play.
I noticed they recently also came out with a flip key option to combine key and remote, might get one of those as well.
Is it worth getting the indicator flashing loom option? I guess that makes your exterior indicator lights blink when you lock/unlock?
