- Joined
- Jul 22, 2012
- Threads
- 571
- Messages
- 16,073
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Thanks guys. Your comments keep me excited and wanting to keep making new parts and solutions.
We actually have a ECU /TAC module bracket that bolts to the emissions mount in the left wheelwell almost ready for release![]()
Nice! You fj62 owners are lucky and still have dash pads available. I have to remove mine when my rust farmers dash pad gets here so i might kinda poke around in there to see what i can clean up.
you probably couldnt get the switch to work because the PCM didnt have the IAC drivers. I removed the AC stuff from my thread and have been meaning to put it back on there for a while now. Heres a few links for the AC.
Gen3 Air Conditioning
going over all info for utilizing the pcm to control a/c on a swaplt1swap.com
There are pics in this one of what to look for for the IAC Drivers DBW to DBC Conversion 03+ Harnesses - https://lt1swap.com/cable_conversion.htm
its basically any PCM that can run a cable throttle body. Without this driver, you cant send a 12v request for the AC.
Haha, dude, dude you're not kidding! I had put it off and was just letting the harness stay on the workbench as long as possible!! Once I started going through things, I realized that it was all sounding familiar from the last one I'd done. Its just been slow and steady sitting here working on things, trying to figure out what diagram I needed, while the wife watches jeopardyNice work, I’m getting ptsd just seeing the wiring photos![]()
Doing your own wiring harness is a bold move. I applaud your bravery.Haha, dude, dude you're not kidding! I had put it off and was just letting the harness stay on the workbench as long as possible!! Once I started going through things, I realized that it was all sounding familiar from the last one I'd done. It’s just been slow and steady sitting here working on things, trying to figure out what diagram I needed, while the wife watches jeopardy.
Love the speed of your progress on this. You’re absolutely crushing it. And I’ll vote for routing the harness on the intake. Looks so much cleaner that way.Haha Yea, there's almost too much information out there, you have people that have posted the factory diagrams and others that have made their own pinouts with suggestions....You definitely have to decipher what peoples intent is, and have lots of patience. Like I said, with mine the seller cut off both bundles going down to the trans with O2 sensors, so that took a little longer to clean up. Plus, not everyone wants to keep cruise control and Factory A/C and other options, so a lot of info is conflicting
But at the same time its only possible because of all the diagrams, pinouts, and information that people have gathered, so I have to give a shout out to all the people that don't just do something for themselves but continue to support others...Huge resource!!
Especially you guys on here with a lot of the big answers to keep me moving along!!! I would have figured something out eventually, but probably wouldn't be as clean!
I got all my O2 and MAF connectors soldered on last night, and added the CPP wire, and PIN 17 for the 12V A/C Signal, just waiting on my BP Automotive fuse block to arrive tomorrow. I bought the stuff from Mouser to solder the PCM per the mod on LS1 tech, referenced on
Modifying P59 Blue/Green PCM's for Analog 12V A/C Request
We'll see what my motivation level is when the pieces arrive... I think this is the most simple way to go (other than the actual PCM soldering part)to get everything I need, A/C request, high idle... we'll see when the time comes, but for now, I just want to make sure all the correct wires are in the harness, and I am ready to get the PCM tune done once and not several times....
I mocked up the harness last night, (it Fits) just trying to decide if I should route the main harness from the fender to the engine directly (similar to how GM did) or if I should push it back a little under the brake master cylinder and up along the intake, to make it a little cleaner, just needing heat protection and spacing from exhaust.
Thanks, its about to slow down a little, I am working again this weekend, then we go on a Switzerland vacation, then I get back just in time to go fly fishing with @rkymtnflyfisher in Montana... so I have been trying to work on it as much as I can. Its getting there!Love the speed of your progress on this. You’re absolutely crushing it. And I’ll vote for routing the harness on the intake. Looks so much cleaner that way.
Before you bolt this in, would it be easier to cut into two halves to have easier access later??? Just trying to be helpful, not a criticism,Well I moved on to 18ga steel, much easier to work with (with the mig I have). I got everything cut, bent & tacked up. Checked the fitment & got it ready to weld.
View attachment 3921858View attachment 3921859View attachment 3921860View attachment 3921861View attachment 3921862
Glad I spent the time, plan to be driving this a lot & using A/C in the summer, so I want to have a radiator and fan that will keep everything cool! Should be able to weld & maybe get some paint in this tomorrow.
I appreciate it, I have thought about it... a lot of early 90's GM stuff was split in half (top and bottom) before they went to one-piece molded plastic ones. It definitely makes it easier to get to the fan clutch, fan, and water pump without draining and removing the radiator. Part of me just wants to leave it one-piece for now and if I have to remove it down the road I can cut it and weld on tabs and nutplates.....Before you bolt this in, would it be easier to cut into two halves to have easier access later??? Just trying to be helpful, not a criticism,
Ty!
