EscapeWagon62
- Thread starter
- #341
Orienting the oil seal worked.
Still leak free
4WD light stopped working again. Ordered in a replacement switch in case we had buggered the other one during the install. Turned out we did (probably mashed the wires where they exit the switch making the connection inconsistent)
Bench tested the replacement then test fired it on the vehicle before the swap. All good now.
I think so but pricey.Cool. Are those switches still available new?
Is the issue that the springs on the throttle body are spec’d to deal with both the throttle and kickdown cables and once you go manual there is too little pull back so it hangs up?Ok. It was 17 degrees today and my idle hung up (1,000-1,200 RPM)
Quick check under the hood and once again it’s the dash pot.
Found a thread by lambcrusher where he experienced this after his auto-manual swap.
I’ll shorten the adjuster screw on the dashpot so it no longer functions and see how it feels.
FJ62 Dashpot
forum.ih8mud.com
That is my assumption.Is the issue that the springs on the throttle body are spec’d to deal with both the throttle and kickdown cables and once you go manual there is too little pull back so it hangs up?
Yes, I ordered 50ft and did all 4 doors. I have about 15 feet left over.Was 50 feet of the flocked channel what you ordered to replace it on all four windows? What was the process? Did you have to remove the door cards? Thanks in advance!
I have zero electrical skills as displayed after my H55 swap.I've got to give this a try! My windows are unbearable.
Used Parts: | 60 series year: |
clutch fork | 85+ |
clips for fork ends | 85+ |
clutch fork hub | 85+ |
3F bell housing: 4/5 Speed Manual | 85+ |
Flywheel | Any manual 60 series |
inspection cover | 85+ |
tranny cross member | 85+ |
Transmission tunnel cover plate | Any manual 60 series |
Driveshafts (if not modifying existing) | 85+ |
Pedal bucket/pedals | Any manual 60 series |
31210-60070 Clutch Cover | ? |
