And the final (I hope) piece of the equation. I was going to check for exhaust/intake manifold gasket leaks. While hunting one of the top bolts of one of the heat shields…..my eye spotted an unconnected ground. It was obviously disconnected when I installed those gaskets and was sitting up under the EFI….contacting metal but not connected which explains much.
Field tested up and down hills, let it heat soak then drove it again. Not a glitch in performance.
Another self inflicted wound healed.
I believe it is. It was sitting in a place where it touched metal but not being attached properly likely explains the intermittent nature of the bogging situation. It was a sudden cutoff so losing ground on injectors seems to fit the description.
No updates of significance other than to say….MAN IF FEELS GREAT TO HAVE A GEAT RUNNING RIG AGAIN!!!! I’m driving this thing everywhere, short trips, long trips and trips I make up just to have an excuse to drive it.
Thanks to all that provided advice on this thread and a couple other ones I created while I chased my issues down.
What are your thoughts on 5 speeds and 4.11 with your tire selection? I’m going to get a set of 31x10.5r15 at 30.5” tall and I’m thinking it will be just fine at a little bit of elevated rpm at a 70mph cruise.
The truck is stock exhaust with cats and full insulation.
Overall I’ve been happy with the setup. 1st gear is low and if I don’t come to a complete stop at a stoop sign I’ll roll off in 2nd. You do have some extra RPM at freeway speed but I live in a hilly area and the lower gearing allows for solid hill performance. IF THERE WERE non-muddier 32s it would be a perfect mating. Mine is mostly a road vehicle so off road muddies would not be enjoyable.
Put the rig through it’s final quality/reliability checkout ride 1:45 through the back roads (very hilly) of MA and down to Rhode Island.
Zero issues so life is good.
Stopped by Toyota of Smithfield in RI and had Noxudol (used byToyota for theor warranty Tacoma/Tundra frame rust prevention campaigns) sprayed on the frame, wheel wells and under carriage.
I had no rust issues since the original owner had it undercoated. Thought it was wise to get that refreshed.
Now that the rig is running great I’m knocking out a few remaining items.
Passenger window is slow and the power door locks sometimes (40% of the time) don’t unlock on the passenger front and rear.
Removed and disassembled the driver door window/lock switch assembly and cleaned contacts (Photo stolen from another thread since I didn’t grab all the shots)
The door lock contacts were really sooty and the others had soot but not horrible.
Power door locks now snap to attention…..on to the passenger door to figure out the slow “UP” function. I had previously replaced the window felt, I’ll check for alignment, connectors etc on my next avail Sunday afternoon.
OK - One more problem behind me.
The rig starting having issues where it would crank but not start. I've already been though all of the sensors in the water jacket, MAF , had a new fuel pump put in etc. etc.
etc.
Took it to a buddy that is a master diagnostic Lexus technician. It took him a week but he found it. As with many things on Land Cruisers it is generally the simple stuff that causes problems.
Well......apparently a PO had replaced the body mounts. When they lowered the chassis onto the frame they pinched the wiring harness (drivers side rear of vehicle). The fuel pump was getting power but very low amps which is what had him chase down the wires inch by inch.
Here is the offending wires in all of their glory. Flatter than Herman Munster's head!
Also probably explains why some of my earlier symptoms (stuttering generally after a right hand turn).
Been running it for three weeks now and it's perfect. Even starts first crank which the rig had never done consistently.
Got rid of a tick in my engine.
Replaced the push rods and readjusted valves.
One rod may have had a small bend but it could’ve just been a valve out of adjustment.
Happened to have a full set of brand new OEM rods in my parts room.
It was time for an oil change, inspection and A/C service.
While it was there I asked them to do a compression test.
I know this rig had blown a freeze plug back at 160,000 under previous ownership (2 owners back) and had the engine rebuilt but I never could find the service records on it. Thought it was worth doing the test just to see how things were. I figured since I already replaced the transmission with an H55, this was the only lingering question I had on lifetime reliability.
Good news - it's dead on 170 PSI across all 6 cylinders.
Also had them do a valve adjustment. I have always done this myself but I have to say, the Lexus tech is a valve whisperer. That or I'm a terrible valve adjuster which is entirely probable.
This engine has never sounded better.
Well, I’ve been using the rig as a daily driver since selling off my LX600.
One developing issue was with starting. Sometimes I would turn the key and nothing would hapoen (like when you have a completely dead battery). If I jiggled the key/lock cylinder and tried again it would fire right up.
Did some other tests and reached out to the forum for advice.
Turns out there us an ignition switch right behind the lock cylinder that could cause this type of anomaly. @Spike Strip even noted that the switch is only good for about 30k cycles and more cruisers are starting to exhibit this behavior.
The OEM is no longer available but City Racer stocks a Japan built replacement which I installed. All is back to normal now.
