The auto isn't electronic controlled by the button or anything else.
Thanks you @Godwin and @tmxmotorsports Your feedback got me thinking straight again.
I have just gone to retest this and BINGO!!!
Somehow (probably because I was such a spaz after the wiring issues etc and wansnt of sound mind) I tested 4wd last night with hubs UNLOCKED. We must have locked them at the shop and I just instinctively turned them last night assuming I went to lockk.
I just drove it with the hubs LOCKED and it slipped right i to 4wd without issue or buzzing. Tried it at several speeds is all well.
I feel a little dumb right now (and yesterday sending out a 911 on electronics when it was a vacuum problem) but elated that its working as designed.
@Skniper I know your are just a few days behind me in your swap. Just assume Ive done all the dumb stuff so you dont have to![]()
Saving this idea for a later date! Not a fan of the new road noise that comes through there haha.For you OCD folks out there.....whether 60 or 62.
I know these rigs aren’t designed to be quiet. I had done quite a bit of sound deadening prior to the H55 swap.
I noticed that the transfer case lever has two boots (inner and upper) whereas the stick shift only has the upper.
I could hear some road noise today and decided to address it now (I don‘t have the jute or carpet in yet but the road noise from the 5 speed shifter wouldn‘t be improved.
Tools:
one inner-tube (car, mountain bike). I used one from my winter fat bike.
one pair of scissors
one leather punch tool for holes
This provides some equivalency to the dual shift boots on the transfer case. I’ll test it out, maybe add another layer if needed.
Big fan of DNPLooks great! How do you like the DNP carpet kit? High quality and very close to OEM? I am potentially going to tackle this in the future and want to use the best quality kit that is closest to OEM.
Hmmmneat idea on the bike tire under the shifter boot but there should already be a inner shift boot, maybe you're missing it? That bike tire won't last long with the back and forth movement of the transmission pivoting on its mount over time
She looks perfect! So stoked for you!Today was new shoes day.
While I love the H55F, the gearing with stock tires was just too low.
I put on some 31x10.5 BFG All Terrain KO2s and it evened out the gearing perfectly.
They also look perfectly proportioned in the wheel well on a stock height suspension.
