- Joined
- Jul 22, 2012
- Threads
- 585
- Messages
- 16,588
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
That looks awesome. Those fans are really good
The DI is nothing to be worried about. L86 is all aluminum and run very cool. This rig will see trails all summer long with 2 kids and AC plus it’ll tow a camper there and back. I wanted all the cooking I could get and still run like stock. These will also ramp up and down with AC pressure so it should run Icey cold with the new radiator.How hot does it get in your part of Texas? I’m on the fence yet on any LS/LT swap here in AZ as I know others have struggled with keeping engine temps in check here. The DI aspect of an LT concerns me some too, but the Torfab solution is very tempting…
Thanks! A couple questions for ya:Let me know if you have any questions!
Next up was an AFM oil restrictor plug which is installed below the intake into the VLOM. This keeps the hydrolic lifters, which unlock/lock during AFM from activiating and collapsing. This plus having SWAPTIME delete AFM from the tune means is a cheap way to hopefully avoid lifter failure.
Pull intake, pull big Allen plug behind oil pressure sensor, pull screen out, drop in restrictor plug, reassemble
Is the idea here with the programming + essentially a plug blocking all the lifters, you aren't going the more mechanical route of putting in 8 plugs further downstream?
Where did you get that plug insert?Next up was an AFM oil restrictor plug which is installed below the intake into the VLOM. This keeps the hydrolic lifters, which unlock/lock during AFM from activiating and collapsing. This plus having SWAPTIME delete AFM from the tune means is a cheap way to hopefully avoid lifter failure.
How in the Heck did you get ahold of mitch at Swaptime.... i've tried phone calls, emails, FB message, IG messages multiple times. I guess smoke signals are next for me.
Trailen DesignsWhere did you get that plug insert?
Is that the right name? Not finding anything.Trailen Designs
It looks like it's kind of a more sophisticatedly designed version of this? VLOM Oil Galley Feed Plug | Crazed Performance R - https://www.crazedperformancerepair.com/product-page/vlom-oil-galley-feed-plug
Thanks! They’ve gotta work on their SEO.
