Could you please post a link to this pin lock?New hilift mount with a pin lockView attachment 2087352
Lee did you port you’re own box for hydro ?April 2022
Rebuilt my steering box with a 105 shaft.
Getting good at these now.
I was scared of breaking it in Moab.
View attachment 3519712View attachment 3519714
I made an nmo mount for the antenna hole in the fender too.
Care to share your current battery setup?
Which antenna are you using? I have your mount with the common short stubby antenna mounted currently.I made an nmo mount for the antenna hole in the fender too.
I think I am using this one,Which antenna are you using? I have your mount with the common short stubby antenna mounted currently.
This is the progress on the current (haha) set up.Care to share your current battery setup?
Yup, I have ported a couple and Rebuilt a few too. I also made a Tap placement template too.Lee did you port you’re own box for hydro ?
^^^^Bottom of little sluice.View attachment 3520026
Did the Rubicon, took 2 pictures.
More testing Delta armor
Those km3s had bad gas and burped the entire time.
