My 76 1UZ build
Really? These are the HD pickup truck springs, aside from a ridged road ride I wouldn't think I would get any compression for wheeling(?) Or do you think they will act more like a progressive spring - soft on top and harder as they flatten out? I can see that that makes some sense as the uber thick springs are almost flat.
My Red Pig , when delivered driver said weight in excess of 5000 lbs! Springs you bought are for a Pickemup with no weight in the Ass 🤔😉. 🐷s Ass is a lot heavier 🤔😉👍
This is the weight on my pig with a swing out and spare, roll cage and SBC with a slush box.
I have those springs on my FZJ75 pickup. Harshest ride I have ever driven but, as others have said, the pickups have no weight in the rear.
@RUSH55 Coincidentally, the 1UZ is 200lb lighter as well.
OK, I had just a little bit of time this weekend but did manage to measure things up. The old springs and the new ones are exactly thickness at the center (1.9") minus the heavy flat load springs, so as suggested, I will try them out unchanged. Especially since pin to pin length is longer so at least in theory that will soften it a bit. My main concern was not being able to get compression on the trail - but I'll start here and see how it goes.
Quick question though - for the fronts I am going to install 6 degree shims, these will cover up the centering pin, do you rely on compression to hold the axle in place or put a plug or section of rod in there to ensure centering?
Pretty excited to get those axles under her - just have to ream for the TREs and weld on the shock mounts (looks like they will just fit between the hub and the brake line tab.
Now if I could just get the adapter for my black box I could really get moving...
It depends on the design of the shim, but you can get a spacer for the head of the pin, or you remove the spring pin and put the pin thought the shim so it still sticks out the same amount as before.
Cool, so not compression - I will figure something out. I have to move the pin back an inch to recentre the axle anyway (the j70 springs push the axle forward an inch)
yeah, the head of the pin should still stick out the same amount as before.
Its too bad the shim is cast, would be easiest for me to drill and weld in a plug in that to correct the offset, not looking forward to drilling through 2.5" of steel...
Edit: ordered bolt spacers and longer bolts, will drill a new hole in the axle mount and shim to correct the offset, easy peasy
I was just going to type this, offset the hole in spring pad, not springs, good stuff.
Another quick question, I have to ream my knuckle arms to take the 1 ton taper, any issues with flipping the steering tie rod from the bottom to the top? the thin end of the new tie rod is 2mm thicker than the thick end of the old one so there will be full contact with the new TRE. Just thinking higher is better, a little less likely to slam into a rock and perhaps a bit less bump steer.
