Builds Megadoomer Build
The tie rod is now in front of the sump part of the pan.
Making a sway bar is really going to be a challenge. That was part of my task today after getting to motor in but we spent that time pushing it back.
Yeah Doomey, those additional supports on the hoops look great!👍
How much clearance between the firewall and heads now that it’s moved back?
1 inch on passenger side and 2 on the driver. Probably need a custom transmission dipstick tube.
you can see the mount is centered.
The passenger side after we modified it.
Sweet, and now you say the headers will work too? Good news!
Are you planning on running a mechanical fan or electric?
Theoretically the headers will fit now. I had them at my house because I was getting ready to send back and couldn't check them. The passenger collector flange was probably into the mount bushing about 1/4". So moving it 2 inches should be plenty.
I am going to use the stock clutch fan. After having electric fans on the SBC I am not really a FAN of them. They draw so much and were so loud. I will put a small pusher for the A/C.
I can't remember if I asked you, but are you using the same exhaust routing as the old setup? I had one heck of a time finding space to run the pipes, but the pto had a lot to do with it. Where does it cross over to the other side?
And it got past the front yoke with no problems. I thought on mine it was tight between the transfer and frame.
Well I have an NP205 and it may be more narrow. The only issue with the h pipe is it can be a collection for moisture. I haven't seen any issues but I do hit the skinny peddle sometimes and maybe it blows it out.
I was helping Steve with his truck yesterday. So for all of you that think I am only take:flipoff2:
He was changing the fuel pump and got some neighbors to help lift the bed off.
After that I creeper'd around under the doomer. In a strange cosmic event my old collectors and exhaust fit in perfect with the new headers. Perfect alignment and drop. Ill have to cut a few inches off where it goes into the h pipe because the motor went back, but that was amazing to find out.
The other thing was to try to find a place for the sway bar. It is not going to be easy. So I have a question and would like input. 2 questions really. What are the holes in the middle of the 80 radius arms for? And can I attach my sway bar there? Its about 2/3s of the total length so I'm thinking about leavers and maybe make the torsion bar thicker or the link arms shorter?
Sumtin like this.
