Meet Dick the Kruiser, and a few questions. (7 Viewers)
Paragon Indiana
Good day, Ih8mud!
You guys are the best you know!
My wife and I recently bought a 1975 FJ40. It had been in a warehouse since 2009 when it was shipped to Indiana from California by the previous owner. It only had five miles put on it from when it was sold in 2009.
The previous owner put a knockoff Holley 2 barrel carburetor from Amazon on it to get it running for an easier sale. It ran great for having some very old plugs, wires and this crap carburetor. It had a high idle, I thought I could dial that in, ha! Thought?!?! I now have it where it will die at random times whether I have the idle screws out running rich or turned in with a lean lower idle. Idle set screw on the linkage is out where I think it should be, I can get it to affect the idle then back off to where it doesn’t.
So, I’d love to get this to a point that we could take short local trips without fear of being stranded. I have two other carburetors that came in a box with it, I think they are Toyota originals. I guess they both have stripped screw holes on the fuel bowls. Any suggestions on a potential carburetor rebuild mechanic? I’m not sure I’m ready to tackle it. Is the Webber carb the way to go? Or just wait and bite the bullet and go with the Holley Sniper EFI?
Awesome pic stolen from @timmyisinthewell
So how how old is the gas? Have you put on a new fuel filter and added some gas dryer to the tank? Your air filter looks dirty. So where is the timing and valve lash? How about the dry and wet compression numbers. Scrape the aluminium contacts for the spark inside the cap.
Gas is new, fuel filter is new, air filter has been replaced. Timing, valve lash, dry and wet compression? Good questions, I don’t have answers for you. Spark is good even with the old plugs, I have new plugs I will put in once I have the carb figured out better.
You're working backwards. Timing, checking compression, checking idle vacuum, and valve lash should be your first steps. You need healthy vacuum for the carburetor to work properly.
This all sounds pretty intimidating to me with the little wrenching time I have and my experience in doing this type of work along with lacking some of the tools.
Would it run well, like it did before I started messing with the carb, if those things were off? I’ve drove several hundred miles in the few weeks I’ve had it.
These are a good option if needed
Post some pics of your other carbs so we can get an idea of what you have to work with
I will get some pictures this evening and post them up. Thank you kindly for the link! I will definitely check it out.
Break each up into bite-sized tasked and you will find they aren’t bad at all. You’ll need to learn regardless if you plan to maintain this vehicle yourself long-term.
“Running well” can be subjective (especially if you only have one frame of reference, your own vehicle), that’s why you need to make sure your baseline settings and engine health are there. The ignition timing could be 2-3 degrees retarded and the engine might have 90psi of compression and it still run smoothly but be super down on power.
Personally I would recommend an OEM carb but you need to check the basics first. Usually the carburetor is the victim, not the culprit , as Mark @65swb45 says often.
This is the gospel, right here. Get a baseline. Don’t just throw parts at it.
When you have the information listed above, these guys can give you better advice.
If you have a factory carb that requires a replacement fuel bowl as part of a rebuild in my shop, I can help with that.
It sounds like you may have a vacuum leak. Spray carb cleaner around each vacuum connection, the intake manifold and the base of the carburetor as well as the adapter between your carb and the intake manifold with the engine running and listen for a change in idle speed. You can't tune around a vacuum leak.
Just so everyone knows how “Dick” got his name. My wife and I were joking about this door had to stay as it is, so maybe I would make a swinging bar door with it or something rather than refinishing it. Later that evening our twin granddaughters came in and asked about our new Kruiser. My wife quickly responded with “Dick the Kruiser” due to the door. :lol:
