Builds Fly By Night (19 Viewers)
i remember another time wrecking the steering box mounts and welding it back together on trail with batteries and jumper cables to hold 7018, or maybe 6011?
I’ve got pictures of that
And a few others from that trip…
Right arm! 🙌🏻
So how are they valved? Any comments on fitment?
Right arm! 🙌🏻
These were the same part #’s @YukonCruisers used on his, the 5165 series.
They come with optional sleeves you can install in the eye bushing to run a 1/2” bolt (like what is used on the Ford towers), otherwise the bushings are 5/8”/16mm ID which fit everything else on the 55.
BIL 25-187724 5165 (Front)
This part has 11.26″ of travel, measuring in at 27.4″ expanded and 16.14″ compressed with a 360/80 valve rating
BIL 25-187717 5165 (Rear)
This part has 11.26″ of travel, measuring in at 27.4″ expanded and 16.14″ compressed with a 255/70 valve rating
They come with optional sleeves you can install in the eye bushing to run a 1/2” bolt (like what is used on the Ford towers), otherwise the bushing are 5/8”/16mm which fit everything else on the 55.
Bookmarked, thank you 👍🏻
