Builds Fly By Night (10 Viewers)
Started my Sunday morning insanity by cutting up the rest of the 3/16” fishplates that will be used for all the new suspension hangers. I’ve been cutting so much with the grinder in recent weeks that I’ve developed some kind of tendinitis in my right elbow. With all the money I’ve spent on 15 packs of cut-off wheels, I could have bought a plasma cutter by now and saved my elbow.
Just go buy a plasma cutter! One of the best investments, truly is magic in a box!
Mike
So, hey - Pig on the Brain.
Called the fellas at Cruiser Outfitters and ordered a set of bushings. Big thanks to Bryce for that hustle he put in his step to go grab a set and put the metric calipers on to verify the 40mm OD/ 18mm ID dimensions for me!🍻
This afternoon’s step of forward progress was more like a left turn down a spur-road to go gaze off into some hellacious canyon. Pulled out the oxy/acetylene and liquified some rivets and factory welds on the rear inner c-channels and got them removed. Fortunately, the damage wasn’t too bad. The passenger side is the worst of the two. Right now, though, is the time to take care of this, rather than 5 years from now, as this project comes to a close.
Passenger channel on the right. Couple spots there getting pretty thin.
The main frame isn’t too bad, but I think I’ll hit it with a sand blaster to flush out the corrosion before coating.
Yeah I got a Wuhon special plasma and it’s already paid for itself in cutoff wheels in a few days. My friend uses his every weekend rebuilding his bronco and had hundreds of cuts with it. $215 delivered.
If Doomer isn't around, you'll be able to jerk me out of the UT mud with that one. Nice work!
Of course, if he isn't around I won't be following him into the muck.
Lots of thought going into this, turning out great!
Have you given the rear bumper any thoughts and how it will bolt on?
How I’m thinking in my head that it’s gonna bolt on is via some mounts welded onto the new crossmember with some captured nuts.
The top of the bumper is going to be at least two inches higher than the frame come out maybe 4”, 90 down for a couple inches then 45 down to meet the bottom of the frame. Wanna pie-cut the ends and then transition into some sliders for the rear quarters which will be square instead of round pipe. Pretty much a slightly less hillbilly version of what was on there before.
