99 miles to the new sty!
Will high temp brake grease do for the new gear? Should be here in a few days :D
Maybe. Need to make sure it's compatible with plastic (assuming you went with a non metal gear). I would use something like a white lithium grease. Lots of different brands and available most anywhere.
Boom. that's the pic I was looking for !thanks. So that alone will do the trick re bypass?
All this talk about the pic, I thought I would copy it here:
This works well.
Related question. Should I use heavier grease on the pinion gear that is obviously not plastic and has much larger teeth?
Another question. Should I be able to spin the motor shaft with the motor installed ? Seems I can spin a whole turn before it engages. I dont wanna brake a finger here when I take off the vice grips... Seems there's only one way to assemble this thing 😏
Back at it again :D. I tapped one of the mechanism mount holes to an M7 and chased the others so I can throw out these sheet metal screws(reported earlier they were wood screws). Bench tested the mechanism w the new gear and seems to work well. Next challenge will be getting the dash switch to operate the window once its remounted. Scored new junction block and key courtesy @ToyotaMatt too!😍😍😍🔥🔥🔥
@RUSH55 correct on the gear lash
here's a vid of the bench test mechanism test
Very nice. Ever since I bought my pig I have been pleasantly surprised that Toyota still carries that junction block. One of the first things I bought.
