- Thread starter
- #261
Will high temp brake grease do for the new gear? Should be here in a few days
Maybe. Need to make sure it's compatible with plastic (assuming you went with a non metal gear). I would use something like a white lithium grease. Lots of different brands and available most anywhere.Will high temp brake grease do for the new gear? Should be here in a few days![]()
All this talk about the pic, I thought I would copy it here:Boom. that's the pic I was looking for !thanks. So that alone will do the trick re bypass?
thanksAll this talk about the pic, I thought I would copy it here:
Builds - A pig for Father's Day
I've never heard of a FJ40/55 alternator not being able to run the AC. I would get a FJ60 style internal regulator style and run the charge directly to the battery. You will need an aftermarket amp gauge but I run this style on my 40 and 60 (of course) and it has an AC. Keep reading. Your...forum.ih8mud.com
Now look at you go!I remember when I used to think taking this piece out/in was difficult![]()
Yes, that was done when I redid the gauges. I got all LED's. some from @ToyotaMatt and a few from West Marine. here's a better pic.Looks great, Did you upgrade the light bulbs?
Related question. Should I use heavier grease on the pinion gear that is obviously not plastic and has much larger teeth?![]()
3 Oz Synthetic Grease
Amazing deals on this 3Oz Synthetic Grease at Harbor Freight. Quality tools & low prices.www.harborfreight.com
This works well.
Ooooohhh...Yes, that was done when I redid the gauges. I got all LED's. some from @ToyotaMatt and a few from West Marine. here's a better pic.
I used the same Super Lube. The company states it can be used for wheel bearing grease.Should I use heavier grease on the pinion gear that is obviously not plastic and has much larger teeth?
didn't know they still carried it.Very nice. Ever since I bought my pig I have been pleasantly surprised that Toyota still carries that junction block. One of the first things I bought.
82670-30020 - Block Assembly Junction Ourisman Toyota Parts
Save Money On Your Block Assembly Junction (8267030020) For Yourtoyotaparts.ourismantoyotaofrichmond.com
