So I'm obviously in deep on the truck right now... upon pulling the transmission and transfer case I found the typical gunked-up mess.
The kids love that they can stand up under the truck and pop their heads in.
I rented a high-temp pressure washer (different brand than Hotsy, but same type of machine) after trying in vain with simple green, a scrub brush, and normal temp pressure washer. The difference was immediate.
While I already had the rebuild kit for the transfer case as well as new clutch parts I of course found a few things here and there that need replacing. Flange studs, driveshaft bolts, parts of the transfer linkage, etc.
I also took the time to brush paint the bell housing with John Deere Blitz Black. Give the cast iron some protective coating as the high-temp pressure washer removed a bit more than just the gunk. The nice thing about the pressure washing is that it essentially did all the surface prep for a nice coat of paint to go down. I just did a quick wipe down with lacquer thinner then put the paint down.
I have to keep reminding myself, during cleaning, that I'm not restoring this truck. Cleaning up excessive grime and muck and making necessary, quality repairs. I could soak up too much time going OCD on cleaning every piece of the housings and painting small parts. If I go too far into cleaning, detailing, prettying things up then I'll be here forever...
Assembly has commenced...
