you’ll be pointing it up more than 7 degrees then i imagine. i’m assuming at this point you haven’t mocked that up?
Depends on your drive shaft operating angle I guess if u want to run single ujoints. My drivetrain is pretty short so I don't have double cardin. The driveshaft angle isn't that steep on mine.@White Stripe that’s true. i could probably point it straight at the transfer case. my bigger question is will the two of us using this set up “need” a double cardan or will a parallel pinion to transfer case set up work. i fear it’s too steep.
Can you make it a double caliper with those 6 shooter. ?
You could use second set of front calipers for the best parking brake ever.
Are those new wheel bearing hubs? They look shiny.
Well I suppose you could, but don't know for sure. I'll have 4 wheel discs so I think I'll be good. Maybe for a hardcore rig with 40+ inch tires that might be good?
