Build 1973 FJ 40 Build,Vortec,NV4500,Atlas,Diamond
k for my sanity sake how far under your frame does your cross member sit? i still have a chance to modify mine if it will save me sufficient space. mine just feels like it hangs down a lot.
Ok, mine will be 1 ¾" below the bottom of the frame. What did you end up with? That's the best I can get it. I don't have time this morning but I won't forget to get you my rear driveline angle
no prob. i’m actually away for the next week so i’ll have to check when i get home. i’m going to guess i’m 3-4 inches below the bottom of the frame. i might look at your design a little closer and get a bit more clearance. wouldn’t be too tough. ill leave my overall driveline where it is though. ill build some skid plates off that crossmember too to help protect stuff
I haven't yet trimmed the gusset side, no rush, as it might be handy for some Atlas support, or not:hmm:
Deflection Calculator for Square Tubing
ENGINEERING.com | Beam Deflection Calculators
that is so clean! every time i feel like i’m going to stick with what i’ve got you convince me to redo it! i’m just worried about getting my drive line too high with a short rear drive shaft
That may have been my post. If I can offer any advice, find someone local to order them for you and ship to the states. I tried for months and Nice never responded back to me.
I’ve installed them and they seem well made.
I ordered these, and they showed up in about 2 weeks. So I guess they are getting there stuff squared away a bit
These extended wheel studs showed up from Nice Products in Australia. I'm surprised that I could not find any in the US, close but no cigar. They look good, about a ½" longer, and the splines are in the right place. And all other dimensions spot on in comparison to the OEM
View attachment 1915456View attachment 1915457
That’s Great! I called, left messages, and even placed an order online and never heard back. Lol
Hey 64Rotorhead, Have you looked at your clutch slave cylinder and clutch fork location? I didnt see any pics in the thread. Anyway, if you haven't mocked these up yet, I would suggest it before you get too far. My build is very similar to yours (SBC, NV4500, Atlas). Last night I found out that this is a conflict if your motor/trans is too low in the frame. I have a 1/4" clearance now between the Advanced Adapters slave cylinder and the top of frame. I can post a pic if you want. Part of the reason I have this conflict is due to the engine/trans being shifted to the drivers side by 1.5"
Hmmm, I'm thinking yours must be different than mine? My slave sits well above the frame. I have AA engine mounts on a Vortec. If you measure from the top of the frame to the bottom of the AA mounts, it's about 1 ⅛" as I recall. My only concern is how close the slave sits to the exhaust on drivers side. I plan to incorporate a heat shield of some kind
