FAQ 40-series FAQ
Status
Not open for further replies.
Welcome the the frequently asked questions about the Fj40 and Fj45. As Fj55's share a fair amount of components, there may be some links to posts involving 55 series.
The FAQ will be locked, but the topics that are linked to will still be open, so if new info comes up, or someone has a better way to do something, you can continue the discussion in that particular post.
If there are a number of good posts on the topic, the link you follow from here will contain an index of these posts . Hopefully that will keep this post less cluttered.
Clear as mud eh?
if you have any suggestions, or want to recommend a topic to include in the FAQ, or a post with good Tech, PM me. If, for privacy reasons or whatever, you don't want you username given credit for any suggestions, please include that in your PM. :cheers:
Hopefully this section will help.
A good place to start with any project (SOA, Onboard Air, Engine swaps, and Front End Rebuilds, welding diffs Etc) is
IH8MUD Tech Links
A N D
Tech Triva (Which is now a part of the Land Cruiser Wiki) This will include specifics on axles, trans and tcases, driveshafts, special parts, such as SPEEDI SLEEVES etc...
Also, for those Cruiserheads who are working on restoration-type projects and have specific questions regarding the history and accuracy of their projects, we suggest you check into the specific group forums for your vehicle.
FJ25 Owners Group
FJ45 Owners Club
FJ55 Iron Pig Preservation Society
Please use these sections only for those oddball items relevent to these rigs....tech issues on engine, transmission, axle, and other mechanical concerns should remain here in the Tech section, since these are universal to all early models of Land Cruisers.
It has been requested that when I modify the Frequently Asked Questions list, that I somehow make those new links of information known, so I am going to list them in this post as well as in the section that they are in.
We will see how this works for a while.
:beer:
DomSmith H55 info thread including parking brake conversion info for the split case
H55/splitcase into 02/79-40 series
Misc Torque Specs-Use at your own risk!
Lock Out 101
TUBE DOORS
More one-piece case rebuild info
4-PLUS Tire/Cooler Carrier Install
Proper clutch disc orientation
Pre-fitting pilot bearing to transmission input shaft
Over the fender bench seat
Low gearing options/craw ratio
Flywheel step measurments
Power steering fitting sizes for pressure and return lines for ASE and Metric steering gears/pumps.
H41/Orion combo
Weber carburetor information
BEZEL INFO Why the headlamp trim piece is installed with the wide part to the top.
Even MORE valve adjustment info
(now with color pictures)
ARP connecting rod bolts
Flywheel/Clutch/Flywheel Housing/Transmission compatibility
OEM 15” steel wheel info
Transfer case seperator
Oil pan/side cover gasket info...
OEM style electrical connectors
Dash knob refurbish-How to
Hardware/Nuts and Bolts
My Saginaw Power Steering Swap
A very comprehensive thread detailing the install, parts used and where the parts were sourced, by John Smith.
33x950x15 Tire Pictures
Cylinder head leaking oil?
Steering knuckle centering tool instructions
40 Series fluid capacities
Pilot bearing removal
Better application of a Ford Taurus fan, rather than from the ford taurus...
Land Cruiser Detroit locker install info
Stuck Odometer Fix
Instrument Cluster/Gauge info
TBI install on my 40
2F TBI Megasquirt EFI
2F TBi. Weighing options. Howell/Downey/AFI/MegaSquirt
Status
