Builds Whitey Forty - Tilda Bogue Service Station (1 Viewer)
I picked up some bling today from 49Tire
255/85r-16 Yokos and FJCompany wheels.
Pimp city
Got the flip kit and IMS shocks installed.
Rebuilt the center arm. Seems someone had rebuilt it at some point but they missed the part about loosening the spring nut a turn. It was super stiff.
Added the relay rod and the new Dobinsons stabilizer as well.
Upper and lower non-smog housings are still available from Toyota also.
I had to replace that one with the plugs with a new one because it was cracked and did not notice
Last two … all set loose until I get the bumper on. These bumper supports are curved up from the prior jackass but I think I can monkey they back into place
Edit..plates were upside down. Can’t have those pics floating around out there. Will fix when I get back in the shop. Thanks Mark.
I got most all of my stuff back from PowderKeg and I started bolting things back on the mighty 2F with a pile of Overland Metric bolts
One of the smartest things I’ve done in this arena was getting a batch of overland metric bolts/nuts/washers.
So nice to always have a stock of correct hardware at hand.
It’s not cheap but it’s proper.
I like your taste in alternators Nolen; I have had one on mine for 13 years and it has been flawless and reliable. Powers everything no matter what the load, headlights do not dim at idle, etc.
I’ve never used one. The owner had this installed. I’m a big fan of a one wire setup but I usually use a 60 series alternator.
The plates are on upside down.
