What have you done to your Land Cruiser this week? (75 Viewers)
I installed a 4X4 Labs Saginaw bracket mount. Also got my 4X4Labs bumper mounted. Thanks @franklin40 for the encouragement to do it myself. This was my first attempt at welding. Very pleased how it turned out.
After lots of YouTube videos and reading on the forum I decided to tackle welding in my rocker panel. Hit everything with a little weld-thru primer (at least the hidden areas) and started tacking it in place. Lots of tacking and grinding and tacking and grinding. Not as bad as I thought it was going to be!
Thanks for posting this I have to do the drivers side on my 40. Is there any advice you can offer ? And what tool did you use ? Thanks
Take your time cutting out the old rocker so the panels will be tight when you put the new one in. I used my replacement rocker panel to trace the cut line on the old one. Use the lightest wire you can. I used .025 solid core with a 75/25 mix. I have a little Hobart 175 I picked up on craigslist for cheap. The lighter wire definitely allows you to control the heat a little better. Keep the gun at a 45 and it'll help not to blow holes through the metal. There are some pretty good youtube videos on welding sheet metal that are pretty helpful.
Drove it! :steer:Made the 40 mile trip from my borrowed garage to my new house. Finally, after 3 years of ownership, I have a permanent roof over the truck's head!
Gave my 1971 F.5 a little 2F love....2F valve cover and a 60 series oem gear reduction starter... Fires right up...
Got between a rock and a hard place
T
Thank you very much .that info will be very help full.I just picked up a Miller Matic 190 I got a great deal on it.I just need to get a 220 line installed
