What have you done to your Land Cruiser this week? (35 Viewers)
Got a little more done on the console ready to burn it in whenever.
Hand chiseled the last of the PO's crappy bedliner out. Friends don't let friends install (without any prep work) cheap bedliner!
Just put fresh paint on my all my dash knobs. Once they are all dry I will post pics on my build thread. I used Michaels paint pens and a Mr. Clean Magic eraser. The eraser takes the paint off in seconds once its dry. I never thought it would be this easy.
Just started taking my 72 apart. I am trying to keep up with the hours. There are 5 hrs taking the top,sides,seat and clean the inside to see what I have. Some cancer under the front seat othyer than that its pretty solid. All original.
Report back on "the hours" after you cross 3,000.
Painted roll cage, seat frames, glove box, ashtray, gauge cluster, and map light
There had been a lot of rattling/growling coming from the gear boxes and I finally discovered that the front output shaft bearing was wobbling around inside the housing. Whew! I was semi-mentally prepped to pull it all out and rebuild them, if needed. :clap:
I jacked up the front of the truck, then pulled the housing off and the bearing and shaft pretty much fell out. 4,000 miles ago when I inspected the tranny and transfer case before resealing them and sticking them to the back of a freshly rebuilt 2f, every thing looked pretty good. But, I missed the P.O.s screw-up. Apparently, when the T-case was serviced (probably rebuilt is my best guess since all of the gears and bearings are in tip-top condition, as far I could see) he tried to compensate for the extensive wear from a previously spun bearing by spiking the race with a punch, or maybe a chisel, that left, 20 or so, raised marks in the aluminum in an effort to create a snug fit which clearly, didn't work.
So, I emery clothed the spikes a little bit and then reset the bearing in place and chose a 0.0050 shim stock. From the shim stock I cut out 3 pieces about 1.25 inch long by about .385 and pushed them in between the bearing and race at equal spacing around the bearing.
Snug as a bug. Put it all back together with a new seal from Thompson's Industrial, just around the corner from my shop, and no more noise. Grand total, $8.10 plus a few pints of gear oil.
Just curious - when did you put a booster on the 40, or did it come with power brakes?? - I was thinking you were running an older style single style master cyl for the brakes - thought I remember you talking about that some time back. Just wondering what booster you used if you converted it??
LBM
so, today we tried -on memory alone, 8 years later- to find the exact spot where the pic was taken that came just before my Brimmer calendar shot: this one
[URL="https://forum.ih8mud.com/attachment.php?attachmentid=843528&stc=1&d=1387857143"][/URL]
we came just so close . . .
[URL="https://forum.ih8mud.com/attachment.php?attachmentid=843529&stc=1&d=1387857143"][/URL]
guess we have to go back and be more precise ;p
and the reason I couldn't take the 40 is that the brake booster didn't like that all the attention on the truck recently went elsewhere :rolleyes: not only do the trucks know when you get another one, now the parts get jealous, too :mad: :bang:
pristine desert, no 10 miles from the big metropolitan area :cool:
What did I do to my LC this week? Well, I bought one! My first FJ! I'm stoked!
Well its a 40. Thanks for the gentle intro!
I will get some pics up once I get her home. She is 75 miles away right now. Just secured the deal last night. Gonna pick her up on the 1st.
LBM
the '72 came with an OEM booster - my understanding is that the problem with converting an earlier truck is that the fin on the firewall is in the way, unless you use a spacer - but I am not an expert on this
my booster gave up, and I now have a booster/master combination from a 4 Runner - which required minor clearancing at the firewall
I think I finally found the short causing my battery to drain and my cruiser to eat alternators at the rate of one or two a year. Finally got frustrated enough to really dig in and it ended up being something simple, but dumb and hard to find. I guess I had kicked the fuse panel a few too many times, and had slightly bent the backing plate metal part just enough to touch the contacts on the back of the fuse block.
So took apart the fuse block and just finished giving a good backing soda and water bath. Cleaned up the contacts and rebent everything tight and straight again. Going to give the backing plate a nice coat of engine enamel tomorrow so hopefully if that happens again it won't ground out as easy.
Feels good to have finally found it. I've been depressed all week wishing I could find it and fix it so I could enjoy my cruiser again.
Think we're going to go up to the snow with the 40 New Years day and do some product modeling for our new company my wife and I are trying to start. :) OK.. mostly I just wanted to go play in the snow. :)
Cool - thanks.
LBM
