What have you done to your Land Cruiser this week? (22 Viewers)
Sherman-Drove 30 miles and discovered my battery wasn't charging because the belt was loose and glazed. Replaced the belt, drove back and about 1/2 way figured out my replacement belt came loose too and wasn't charging. Good thing I have an optima yellow top. Tomorrow-work on the alternator set up.
Cadet-put on full soft doors for the winter. Started working on the hard top doors.
Tore down a donor t-case , needed a new housing after my last wheeling trip. Ordered a gasket/seal kit. Filled it up with gas($1.59 per gal.)YeeHah:cheers:
got the repaired radiator back in...now i just gotta repair the starter or buy a new one.
... put the gas tank back in, and then TRIED to get the cover to fit. I still have a 1/2" gap between the tab and the door sill.
The good news is that my restoration is almost complete. The bad news is that my 15-year-old son has more patience than I do, so he doesn't understand why I gave up on the gas tank cover "so easily." I don't have a heated garage, and the thermometer was showing 20 degrees F.
Warning: Extremely High Tech S**t!
I got tired of my lug wrench rattling around and taking up space, so I fired up the lathe, cutoff saw, tig, plasma cutter, slide rule, dial indicator, degree wheel...and came up with this: (NOTE: This mod should only be attempted by professional fabricators)
Did a little front body panel paint/work...looks pretty good now..
72, 74 76, 79 fj40
Re-read my manuals for the MegaSquirt. Re-tuned for cold idle. Cranked it up. Wowzers! It started right up! Oh joy, oh joy!:bounce:
Let it idle for about 5 mins. Wouldn't come up to temp. (scratches head) Did I remember to put a thermostate in?? Turn off engine... Oh no... oil pool and coolant underneath. Says to self "oh, dear, I must have made a mistake"!:censor:
I guess I'll come back to it another day. Gotta go shopping.
MERRY CHRISTMAS, EVERYONE!
Replaced leaking fuel pump, adjusted non OEM seats, and installed a new gear shift stick. Still need to replace the steering box and about 10,000 other things.
I love my 40, it ROCKS.:grinpimp:
Put fuel in it, new wipers, cleaned fuel filter, and flushed coolant system.
front recovery points
We put a couple front recovery points on the bumper.
Now to clamp the hi-lift to the top of the winch.
I installed EMU shocks a couple of weeks ago.....
I made mine pull my m105a2 up from my pasture, filled said trailer with misc garbage, used '40 to pull it to the dump and back! I dug it.
OH, tires were at 5 psi. :grinpimp:
Hi All:
"msapers," great idea!
But, have you considered these instead of the (one time use only)zip ties?
Regards,
Alan
Sunday- started the freshly rebuilt 2F
Wednesday- had the new BFG Mud Terrain KM2's put on
Saturday (today)- took first place in stock class at the Wheelers 4 Wishes show n shine, :bounce: then came home and drained out the Joe Gibbs break in oil, put in Shell Rotella for the next 500 miles.
