What have you done to your Land Cruiser this week? (12 Viewers)
Old Teq. New wires. Do you solder? I don't.
I have similar comments, alone in my garage, as she does. I think I’ve even asked “why won’t you strip?” To a wire stripper.
I prefer a good non insulated butt splice + heat shrink over it.
Solid-butt connectors, non-insulated can be crimped, and then soldered at the ends of the connector, before heat-shrink-insulated. Self-vulcanizing tape, under the harness wrap (ACE electrical tape), will keep the connection from corroding. If I try to solder bare copper strands of wire together, all these pokey wires stick out? Soldering without tools to hold the wires in place is kinda tricky.
This, with marine epoxy oozing heat shrink. When I modified/ rebuilt the 3FE harnesses that had been cut at the firewall penetrations ( for the 2FE build) I did a bunch of these connections, which have held up perfectly.
Someone left these on my 40 when it's occasionally parked outside. I was pretty sure it was the kids next door. Turns out it's a very nice neighbor with an '82!
Mocked up the new quarter panel patch so I could mark where the badges and half door mount go. Also pulled off the half door mounts and used the drill and tap to get the broken bolts out. Found these old OEM fog lights on the shelf so put them on. Also used some Eastwood Rust evaporator I had left over on the rear bumper/crossmember. I should be able to tackle the passenger side tomorrow and get the sill in and fitted.
Looks great.
Wrapped up the steering wheel refurb tonight. It’s not perfect but it’s protected now and looks better than it was. Tried to epoxy some of the cracks then sprayed some primer and paint all finished with the wrap.
I need to take this on as well. Any lessons learned from the process?
After 8 years of meaning to get around to a nut and bolt restoration. I have decided to instead put my 79 back together so I can, you know, drive it.
I am closing in on putting the engine engine back in and I have to admit I am a little terrified. 8 years ago I had more confidence I guess, but now I am sweating it.
I bought new shackles and even put some rims with no tires on just to keep the lift height down.
Any advice is appreciated. This is a good running 79 engine and transmission. I hate to lose them.
Slightly less pucker factor might be bolting the chain directly to the block.
That hook/shackle combo would be my only hesitation.
I added a loose lifting strap as a precaution…. But I also did mine with the body on which is much harder since you have to slowly pivot the tranny into the tunnel. There is a lot of weight hanging when installing with tranny/ transfer case attached.
