What have you done to your Land Cruiser this week? (43 Viewers)
img_1283-jpg-copy-jpg.1779896
What code is that blue. ?
T449?
so , .............................................:poof:
i was having some driavbility problems , hesitation on acceleration , on hills up down
after like 20+ hours of diagnostic time i traced to a fuel starvation issue , either sucking air or the pickup tube is clogged ?
i gave some deeeeep thought and came up with this remedy : :hmm:
- i used 1/8 thick solid brass plate
- 5/16 copper nickle allow tubing ,
- #56 100% troy weight silver Brazed the two together
- i held the tube 1/2 " off up the bottom of the tank floor sump
- started up after a new OEM fuel, filter 23100-38010
- also installer 6 new 4mm screws & a new OEM flange gasket
the truck runs and drives normally now , only down side is Not having a fuel guage ,
this is a temporary repair till i can source a good used tank for a 1/79
Done that bf on an old isuzu truck I have. Ended-up being the heat valve on the air cleaner intake not closing and freezing-up the carb. Would drive me crazy in the winter. Run along the interstate to work. Fall on it's face pull-over the 5 minutes and the engine heat would thaw the ice and I could go another 15 miles. Service shop finally found it after a year.
Took stuff apart to then put the same back in...but done right and hopefully leak free.
Rebuilt a spare sm465 adding new input and main shaft. Output drilled and tapped. Orion torn down getting new seals / gaskets. Curse the shade tree that uses ****ing silicon on everything.
Installed tach, water temp, and oil pressure gauges today. All my stock gauges still work except the oil pressure gauge, I plan on getting it back online soon.
