What have you done to your Land Cruiser this week?
https://forum.ih8mud.com/threads/the-hayduke-route-thru-hiking-thread.1268827/
Thanks, @Nothinghead it's all very fascinating really. I planned and obsessed for nearly 6 years till I went for it. John and I hiked the first 30 miles like 5 years ago when I passed the original briefcase to him with both our 83" 40's.
I go 2-10 days between resupply. My base weight ranges typically between 12-14 lbs. Get some popcorn :popcorn:and a cold beer:beer: and go check out my thread, and start from the beginning!
Just took my BJ out of its shelter and did a little test drive. I'm waiting to get into my new garage (behind), few more weeks…
Picked up a new to me warn, think it's a M8000, if someone can help confirm?
Diagnosed why it only works one way. Need to find a new solenoid.
Did some small jobs around both the cruiser and the Mrs surf
And stole some new style single peice doors that are going to need alot of love! Could be worse though!
Very nice! And the garage is really nice! I've been looking for something similar (I think).
Are you building the garage from plans, or is it a custom design? I want something very similar to what you have.
Replaced the 53 year old clutch slave cylinder and (3) heater hoses in our 69 Pig, also known as the "Working Pig" since it's been a plow truck since 1971!
Installed at set of Koito H4 headlamps.
I still need to update my battery cable clamps for ones with accessory mounts to install the dedicated wiring harness. But even without the harness improvement in lighting is noticeable.
Of course while aiming the headlights, I noticed a front side marker light was out. So the FJ40 to do list remains in balance.
Working on the bench due to season.
I'm working on a couple of things. First is making this a two-filament lamp. I'll get into that later.
Second is establishing an earth wire connection that doesn't need the hot green/yellow wire to pass thru it, like it came from the factory (white wire with black stripe is ground and lamp-socket spring seat).
Also, I don't wan't to sandwich a copper with zinc plating loop terminal under that monster lock washer. It would probably work, but, it is not going to look pretty after you take it apart after torquing it down, and I've never seen copper used by the OEMs for grounding on a vehicle, all their rings/lugs on the frame and engine are brass, and they ideally employ a star washer.
I once heard of using lead as body filler. A piece of 'bailing wire' was cleaned and 'tinned' with electrical solder. Then it gets a unshielded solid crimp connector, which is crimped, then soldered. The M12 nut will make the ground connection to the chassis of the lamp, and the lead coated soft steel wire should minimize corrosion at the location of thread/fastener. (I once had a plumber use a section of steel pipe for gas on an outdoor spigot, the galvanic reaction from dissimilar metals caused the valve to fail within six months, and the water was really discolored.) Hopefully the braided copper grounding wire and its connector stays dry with some shrink tube under the fender.
I'm not sure that this is really a trail going anywhere, yet...
Replaced all my break cylinders on my 64 fj40 because 3 had started to leak. Then broke a break line installing the last two cylinders. How it goes some times. I am glad I dug into the breaks though. A couple of the drums and pads were incorrectly installed. I'll rebuild the old ones for back ups when i run out of projects to do.
The good news is all the pads and springs seemed new! I think at some point the breaks were all done with new parts then maybe the car sat for a long time.
The picture below is the passenger rear break drum. I could not get the drum off without unbolting the cylinders. This is how they came off. pretty sure the springs are incorrect. it was not adjusted correctly. I think I have been driving around with this drum breaking all the time. The driver side drum adjusters were both facing up....
I once heard of using lead as body filler. A piece of 'bailing wire' was cleaned and 'tinned' with electrical solder. Then it gets a unshielded solid crimp connector, which is crimped, then soldered. The M14 nut will make the ground connection to the chassis of the lamp, and the lead coated soft steel wire should minimize corrosion at the location of thread/fastener. (I once had a plumber use a section of steel pipe for gas on an outdoor spigot, the galvanic reaction from dissimilar metals caused the valve to fail within six months, and the water was really discolored.) Hopefully the braided copper grounding wire and its connector stays dry with some shrink tube under the fender.
A color photo! What is the world coming to?
Attempt #2. This one was done on a proper mandrel (1/2" drill shank). The black is rosin, I hope. I folded the wire back after it made one full loop, then the two tags were soldered together so it is a complete ring. Really non-invasive way to do this on the later lamps ('75+).
Maybe a nylock nut is better, but, why change what already works (the front bumper is a totally different nylock-question)?
Today I remedied my throttle linkage. After 40 years of pressing the accelerator pedal the ball and socket joints wore badly. I had about an inch + of play before the butterfly valves would open. Having zero luck sourcing new or remanufactured ball and socket linkage I reach out to @ToyotaMatt for some ideas. Of course he has some. I replaced the horizontal and small vertical push rods with two that he got from his Skunk labs that had perfectly rounded sockets. He was able to fit me with the earlier torque rod that did not have the ball on the end but a bushing. I also replaced the bracket that attached to the carb that has the receiver for the early bushing torque rod. The new torque rod also has perfectly round balls that fit snuggly into the push rod sockets. The original torque rod balls were oval and not round and just flopped around in the out of shape sockets. So now everything is tight! No play at all. It’s a nice feeling when I put on the gas. I think it has cut down my 1/4 mile time a tenth or two!
I also installed a nice shiny new heat shield and carb gasket/insulator.
So a shout out to @ToyotaMatt (once again) for having all of this cool st
Thanks for posting these photos. First clear ones I've seen to help me hook up my mechanical throttle components, when converting from cable style throttle.
