What Did You Do with Your 80 This Weekend? (65 Viewers)
Well done, you have more determination than me... I just zip tied it... I'm not going for any purest points.
Please don't tell anybody. I won't do it again. It's really stupid what I did. Not worth it. You don't accomplish anything over the zip tie method.
I saw it as a challenge and saw a way to retain it.
All the scratches on my hands and fingers are a reminder my brain is not always on my side. Just like every time it tells me not to wear gloves, or wear flip flops when doing work on the car or splitting wood.
Wrapped up the crossmember. First step in overhauling crappy rear suspension.
Attempting the Highest Peak in Egypt's Mainland....Gebel Shayib El Banat 2,187 m ASL, Red Sea Mountain Range :
On the way to the foot of the mountain, with a new Toyota Fortuner's 1st desert trip, 3 grups + 2 youngsters :
The beginning of a 4 hour hike/light climb up, summit is visible at background center left :
Rock Balance and a passage :
A small playground, but no time to play, the starting point in the valley below :
The elusive summit, couldn't make it, short 2 hours on daylight and 450m altitude to the peak, a second attempt is in the works ;)
EPIC!...what kind of temps were you dealing with?
plugged in a trickle charger :frown:
  • Like
Reactions: RFB
Looks good man! There may come a time where I either go this route with my own 80 or, (more likely) get another 80 and do some custom link stuff so I enjoy following yours to see how you're getting it done.
Busy week / weekend and a thank you to a fellow MUD member for coming over to help out on Saturday.
White Knuckle
Trail Tailor
This seal
This O-ring and the dizzy o-ring too
4Crawler 1" body lift
Hillbilly body lift tool ... black locust log
New radiator, rad hoses, thermostat, idler and AC pullies, new transmission hoses and all new clamps
Already found the next item on the "To Do" list unfortunately
Thanks, appreciate it! I really wish the gas tank was mounted somewhere else at the factory. Would really open up lots of options for addressing the suspension. The guy that built my quarter panel armor makes some really cool stuff for the XJ/ZJ Jeeps. Bolt-on 3 link and double triangulated 4 link setups with integrated skid plates. What I wouldn't give for something like this!
LandCruiser body on frame > unibody. ;)
You could easily drop a fuel cell where the stock spare was, but to get big capacity then you have clearance issue. I think if you were creative you could have a custom cell made with clearance in mind that is deeper close to the axle and angles up to the rear.
Oh no doubt. But with the gas tank not in the way we could really get creative.
Did cross my mind before. But with the setup I'm doing now it wouldn't work. I want to try and run 14" coilovers behind the axle slanted in and back to avoid having to cut the floor. I also have the big piece of DOM tube in that area for the Ruffstuff swaybar. Would need to be a much smaller fuel cell to fit in the space I have left.
Just remember as you change the angle of the coilovers you reduce the effective spring rate and valving. If you are using 2" coilovers might be an issue.
Yeah. If I can get it to work it would look something like this. Angle won't be too extreme
That looks really good, I look forward to what you come up with! It is not easy to squeeze a 14" coilover under a wagon with decent ride height but that looks like a good plan!
There is quite a bit of work right there, the notch in the frame rail, the double reinforced upper mount, etc. What is that under?
This is the 4WU kit for 4runners and mini trucks. Rear Coilover Mounting
Still TBD if it will work on an 80 due to ride height like you mentioned. If this doesn't work I'll have to go through the floor which I'm not opposed to - but if I can avoid it that'd be even better.
Flew to Oregon, signed the title and bill of sale, spent sat/sun driving it home to MO. 2016 miles, so I blew out the cob webs and broke a passenger window regulator not noticing the window was frozen.
Where in Oregon?
