RUSH55
thanks for shaming me into fixing that exhaust.
You’re welcome. Jeeze, you make it almost too easy
My 74 is out there.I did not know of any cruiser with the exhaust outside the frame.
Well I clearly don’t know then.My 74 is out there.
I'm betting it's not a stock system.My 74 is out there.
Man walks into a psychiatrist's office wearing only Saran Wrap. Psychiatrist says "I can clearly see your nuts."Well I clearly don’t know then.
No pic handy but there are factory hangers outside the frame and the remnants of a heat shield (that someone removed with a torch)I'm betting it's not a stock system.
Mine is 3 on the floor but I do have the super dopey vacuum H-N-L 4WD pull out knob system.Yeah I see zero reason to run it out of the frame but I bet it has something to do with all that dopey 3 on the tree mechanical
My 72 was on the outside of the frame Looked just like the picture, also the skid plate was different no indent for exhaust. My 2 centsNolen - sorry for the slight high jack of your thread. I saw the picture of your muffler and it reminded me that my 1969 has an original muffler heat shield on the outside of the frame while my not original but still very rusty muffler is currently routed through the inside of the frame. Since I will be getting a new muffler I have been thinking about the beat/proper routing. I pulled out my F Engine manual and here is what it shows. Interestingly enough the US LHD doesn’t show the frame in the picture. While the non-US version does show the frame with the exhaust system in the outside of the frame. In fact the piping goes from inside to outside back inside and the outside again which seems not a very efficient routing.
Just to make this more fun than you are already having…..Back to the drawing board......
You should look at moving your axle forward about an inch, the factory fixed rear eye moves the tire forward on compression and now you will move your tire rearward on compression, a 35” tire is going to be close to that rear lip in your ditch test if you are turning into it.
Yeah I'm not a fan of that kit but if I was going to try to make it work I would pull all the leaves out of my pack and cycle the suspension before I welded everything permanent.To be a little fair to this “kit”
