- Thread starter
- #1,361
About 13,000 miles on this engine this go around.
Beyond "acceptable" practice for a stock engine is a tough call for the Cummins engine, I was definitely at the upper limit for a single turbo but compound guys are pushing a lot further on seemingly stock bottom ends so I would assume I would be at the upper middle limits of “acceptable limits”.
The working theory right now is I floated the valves when I was running my second turbo the BorgWarner EFR 7064 Turbo, that turbo would start making boost around 1800 rpm and pull hard up to the 4000 rpm defueling point of my pump (from memory boost was 45+ at the time of defueling) and the engine sounded unhappy and this upper limit, I remember thinking it sounded like someone was shaking a tin can full of nuts and bolts under my hood in hindsight it was most likely valves hitting the tops of pistons.
Thinking back my blow buy issues started at about this same time but I never put two and two together, I removed that turbo and put a smaller more reasonable turbo on the “super” HX30 and I’ve kept the RPM down around 3000 RPM mostly because the new turbo flattens out above that.
New engine should be reasonably bullet proof with the current turbo but able to handle the higher RPM and boost if I get a bug in my butt and put the EFR back on..
