Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 06-12-07, 07:55 PM   163 links from elsewhere to this Post. Click to view. #1 (permalink)
boots4's Avatar
TLCA# 19547
Family haulin' FJ60
Here is a Table of Contents to help find things. These are the main points of each page. Just find your topic and click on the page number in the navigation bar.
  • page 1... FJ60 tear down and 2F engine pull, cut up stepvan and cummins 4bta engine pull
    page 2... rear frame channel removal and boxing, hydroboost adapting, rear disc idea, 203 tcase disassembly, leaf spring painting and mock-up
    page 3... Transgo 4L80E-3 manual shift kit install, rear spring hanger welded, 203 GRB to 4L80e adapted
    page 4... Jerry Nichols No. for 203 doubler to splitcase adapter and assembly, front spring placement, tcase rebuild, drivetrain mock-up (4l80e to 203 to splitcase)
    page 5... front and rear springs mounted, fix 4BT killer dowel pin (KDP), 4BT cleaning and painting, turbo repair and pyro probe placement, LED dash lights, 4L80e to 203 mated, spectrum coating
    page 6... rear axle mock up, 203 drilled/tapped, 4BT and 4L80 connected, 4BT placement, clearance and engine side mounts, downpipe start
    page 7... frame side engine mounts, tranny crossmember and mounts, Art Carr shifter mount, intercooler mock-up
    page 8... Tranny cable connected, intercooler to radiator mounts, doubler/tcase operation and install, rear axle perch welded, front/rear ubolt plates, front axle mock-up
    page 9... front axle mounted, dual battery mock-up and trays, bum turbo, mech water temp gauge placement, dual fuel filters, rear disc brake install, AC compressor placement idea, fixed and improved turbo with link, throttle cable hook-up, front axle caster adjustment, front diff guard and axle truss, hydroboost and brake MC install, power steering box tap for ram assist
    page 10... Wheel spacers, front axle shims installed, Aussie locker in front 3rd, completed downpipe, front axle assembly and longfield super 30 set installed, Marlin High Steer, hydroboost and power steering hoses converted to AN, overflow and PS fluid reservoir mount, brake lines, heater hose routing, lower radiator hose, alignment, intercooler routing
    page 11 rear weather strip lip fixed, 4l80 rebuild
    page 12 rear shackles lengthened, doubler/tcase shifters, rear shocks, front shocks and hoops
    page 13 fender skirts, electric vacuum pump and regulator for tranny modulator, sound deadening engine bay.
    page 14 doubler/tcase shifter linkage, vacuum regulator install, LED dash lights glowing
    page 15 38's mounted, rear quarters trimmed, reconfigured front packs, minor flex
    page 16 fuel pump and cut-off solenoid, wired up t.converter lock-up, spiral baffle in downpipe, reworked lower radiator hose adapter, tranny cooler installed
    page 17 first major trip report, contour fan installed using spal controller, baffle removed from downpipe and downpipe heat wrapped, exhaust routed out back, 366 (3200rpm) govenor spring installed, intercooler pulled and cleaned, rig ramped for flex, front drive shaft started
    page 18 rig gets named, front long spline driveshaft finished, new water temp sender, rear body mount cut for clearance, rear bump stops, first wheeling pics @ TSF, new amsoil air filter with 4" intake.
    page 19 Modify Hydroboost for 1 1/4" master cylinder, bench bleed MC, heat shield for air filter, 8 groove pully alignment on CS-144alternator install, high mount rear speakers, hydroboost with 1 1/8" MC install from chevy astrovan, front fender trim
    page 20 lower body line textured and painted, gutter reseal and paint, boost gauge signal line moved, battery straps, hydroassist ram install
    page 21 wastegate signal line capped, beach wheeling pics and vid, mountain wheeling pics and vids, broke front driveshaft,
    page 22 removeable rear mud flaps, rebuilt front driveshaft with stronger slip-spline, Hilift demount plate for breaking tire bead from rim, tried out BB for internal tire balance, Coretrax tie down strips from rear cargo area, TSF Cruise the Woods pics,
    page 23 rear seat back painted, went back to 44mm inducer on my turbo, wastegate tied shut, made 3" intake for turbo mod, extended front/rear bump stops
    page 24 intercooler and tubing pressure test for leaks, replace passenger side motor mount, made new tcase shifters and extended the levers, console 10" sub box, heater core replacement and duct cleaning, interior firewall insulation,
    page 25 boost leak troubleshooting (gaskets and o-rings), tire grooving, fabbed steering stops, custom intake horn, snow wheeling pics, front shock repositioning,
    page 26 42's (yeah right!), rear shock repositioning, reworked hydro assist mount and clamp, reseal hydrobooster, initial rocker cut and slider mock up
    page 27 tube bending for sliders, pics of inside of rockers,
    page 28 sliders mounted on the frame, car crushing pics and vid, smaller lower steering joint for shock clearance, rear bumper 1/4 sliders,
    page 29 rear bumper mounted, mudflaps fix and remounted, radio flyer welding cart, bilstein 5150s leaking seal,
    page 30 skid plate frame brackets, CB radio info, TSF wheeling testing out Dirtgypsy's SOA, bending tube for front bumper,
    page 31 front drive shaft lengthened/retubed, johnny joint and antiwrap bar links, antiwrap bar axle brackets, Poly performance rear axles installed, aussie locker installed in rear, new front axle shock mounts,
    page 32 Bilstein 7100s mounted, Brokenparts front bumper mounted, rear 1/4 protection bent and mocked, line lock swagelok ball valve and brake line routing, skid plate slapped together,
    page 33 Rubicon 2009 trip report, Antiwrap bar,
    page 34 Front bumper phase 1, massive tire failure,
    page 35 TinyTach install,
Alright fellow forumonians, I've got a project underway and it's time to start sharing. I've lurked here for a while and have absorbed much knowledge, so now it's time for me to show what I've done with that collective knowledge and put it to good use.
So here's the plan, and like all good plans the important part will be adapting to what comes my way.
Cummins 4bta (intercooled)
manual 4L80e
203 to splitcase doubler
SOA
38s
hydroboost
hydroassist
larger fuel tank ***decided to run the cruiser tank instead 10/07***
and some other stuff like:
some kind of insulation/liner for interior floor/firewall
custom bumpers
fender trimming
marlin hysteer
arp knuckle studs
Intended use is a capable all-rounder for trips, DD activities, some towing, and a whole lot of wheelin! It's been almost a year since I sold my last truck/wheeler and the offroad videos on youtube just aren't satisfying my need for the great outdoors, so I'm pushing forward on this project. I've got another kid coming soon so having more room to haul the family became a necessity since my wheelin' "photographer" pulls double duty as a mom.
So lets get some pics in here since all of us seemed to be into the picture books as kids rather than the story books. I'll have a bunch of pics to start with until I get caught up to where I'm at.
That's what I started with.
rear axle out
grill and headlight out
Front axle out
Yup, my seals were shot, bearing grease should be thicker than that. It's being rebuilt anyways.
the brakes still worked fine with that line smashed (wasn't me)
looks good inside
it's floating now
prepped for cut n' turn
this is where I'm at with the front axle so far
goodbye bumper brackets and spring hangers
starting to collect some s****
next I started working on the springs I'm planning on using. The rears will be the chevy 63 inchers and the fronts will be a hybrid pack using a ford ranger rear main leaf. I used a 3 leaf plus overload on a ford ranger I built up and I was happy with the results so I'm going to do it with the cruiser since it's got such a big butt (plenty of room to mount). I have a 4 leaf pack that I'll thinking I'll add one more leaf to start out with and tune from there. The ranger main leaf is 58 inches long so I have a little work to get them under the front, but those flexed pretty well too. I'll just have to build up the pack since the 4bta is heavy in the mid section. I wire brushed and painted each leaf. The chevys are in the front and the ranger main leafs are the furthest away.
front spring mock up. The plum is the original center and since the holes are offset on the ranger springs I figure the axle will move forward 1-3 inches. I wanted to move the axle forward so this is good.
I'm doing a shackle reversal so I don't snag a shackle when approaching obstacles and the long springs will push the mounting point out to the very front.
the rear mount will be tricky since I plan on going through the frame to keep the SO low and that point of the frame just starts to curve out. The crossmember will be removed and relocated.
burned in a front channel and mocked up the spring hangers. So I bought a stepvan for the 4bta and have found that the frame has a lot of steel I can use for fabbing parts. Those hangers were made from that frame. Not bad for living in the recycling age.
you can see the plate I put in there to distribute the weight to both crossmembers on the front of the cruiser. Probably over kill but diesels do produce some good torque.
decided to commit and burn the hangers in. I'm using flux core since I'm doing this outside and am newer to welding than some of you so I usually end up touch-up grinding/flapper wheeling my welds since they aren't the nicest to look at. Paint usually improves the appearace some, or hides it in my case. I'm using a Ready welder II and really like it. Great for portability since I built a little cart to haul my batteries around with. Future plans include dual batteries in the cruiser and a connector wired in for my welder for trail repairs.
I'm out of time so I'll get more pics up tomorrow. Once I'm caught up, pics will probably come more on a weekly basis. I usually get 2 solid days to work on the cruiser on the weekend and after that I upload the pics.
Glad to finally join the ranks and build something I hope to be proud of.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 06-12-07, 08:30 PM   #2 (permalink)
samibattlemaiden's Avatar
wow i hope your one of those guys that hasta sell his rig as soon as he finishes it so he can start a new one case if yah did that i would by it.
but really it looks like you thought it out and are making good progress.
keep us posted
03 Taco 33s some tube an a Winch SOLD Alice
87 Sami 35s toys 6.5:1 SOLD Matilda
84 FJ60 Lifted 33s pizza cutters 5SPD. Rooth "The Mud Butt Wagon"
"Landcruiser cause everything else sucks" Mudrak
samibattlemaiden is offline   Reply With Quote
Old 06-12-07, 08:36 PM   #3 (permalink)
1974FJ's Avatar
Alright! Good to see another 4bt cummins in a cruiser. keep it up
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 06-13-07, 08:01 AM   #4 (permalink)
lowtideride's Avatar
TLCA# 14891
Very cool build, love seeing 60s built.
www.NFCruiserheads.org 2RZ-FE 'D 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 06-13-07, 08:59 AM   #5 (permalink)
brokenparts's Avatar
TLCA# 16127
Lookin good.... chalk another SOA 60 in P-town area! Hope to see ya out on the trails when its done!
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 06-13-07, 09:26 AM   #6 (permalink)
boots4's Avatar
TLCA# 19547
Thanks for the comments already. It's funny how having someone watching what you are doing can be motivating. In fact last night I did some more grinding. I work 12 hour days so I usually am not motivated to do much when I get home from work. So if I do get motivated I usually choose something easy like grinding or pounding. Here are some more pics to get caught up.
Pulled the hood, support, radiator, and disconnected all the little stuff that would keep the engine in
starting to lift
and it's out!
sure is a long engine
there really is alot of room in an FJ60 engine bay
here it sits until now awaiting sale
removed the brake master and booster plus the clutch master since I'm planning on running an auto. I ran a manual in my last truck and would rather wimp out with just two pedals instead of three. Plus I'm looking for it to cushion the drivetrain a little. However, the auto won't be a true auto, more on that later.
started taking off lines I won't need
more to come soon, time to do some work, the funding kind.
Old 06-13-07, 09:34 AM   #7 (permalink)
boots4's Avatar
TLCA# 19547
Brokenparts thanks, I have been watching your stuff too since you are so close. It'd be great to see your rig up close to see how tall it really is. Is it close to being done from your last build-up? We'll definitely hook up an do a run sometime. I recognize some of your wheelin' pics from brown's camp. There sure are some decent trails out there, although it's been a while since I've been out there.
If Florida were closer lowtiderider, your many projects would be fun to see in person. How are you liking the open air feeling of your choptop? I don't think it'd be viable here in portland where we see colder rain, but I bet you dry off quicker after surfing.
Old 06-13-07, 10:30 AM   #8 (permalink)
TLCA# 16127
If Florida were closer lowtiderider, your many projects would be fun to see in person. How are you liking the open air feeling of your choptop? I don't think it'd be viable here in portland where we see colder rain, but I be you dry off quicker after surfing.
Cool, I look foward to seeing yours all finished up and on the trails. I agree about chopping the top. If the weather/climate was different here or if I could store it indoors, I would have already chopped it. Until one of those changes... I've gotta keep the top and the big butt. Got another week or two until Big Blue is all buttoned up.
You should try to make it to the next Cascade Cruisers meeting next thursday at Buster's BBQ.
Old 06-13-07, 10:37 AM   #9 (permalink)
what he said
Mace's Avatar
TLCA# Something
Looks good!
Family haulers are fun
I am kinda gay.......
My Myspace
Old 06-13-07, 10:44 AM   #10 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
Nice build thread!
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is online now   Reply With Quote
Old 06-13-07, 11:01 AM   #11 (permalink)
boots4's Avatar
TLCA# 19547
Brokenparts, is that cascadecruiser meeting thursday 6/21? What time does the meeting start and how long do they usually last (I've got a little daughter who goes to bed by 8:30 or she gets grumpy)? I thought about hooking up with you guys but figured I needed my crap back on the road. PM me any details I'd need if you cannot share them here, thanks.
Old 06-13-07, 11:16 AM   #12 (permalink)
TLCA# 16127
no secrets on the meetings... 7:00 every third thursday (yes to 6/21 queston ) of the month at Buster's BBQ in tigard just off 99 near the Baxters. Meetings are family friendly and usually dont much longer than 45mins to an hour. Alot of people hang out after and BS for awhile but getting home by that time shouldnt be a problem. The link to the local TLC "cascadecruisers" in down in my sig. Click on it and introduce yourself to the cruiserheads over there. Lots of good people from our club cruise this site too.
Old 06-13-07, 11:21 AM   #13 (permalink)
TLCA# 16127
there's also a guy from the club that just finished his 4bt swap that might prove to helpful to you during your buld too.
Hi jack over...
Old 06-13-07, 11:45 AM   #14 (permalink)
boots4's Avatar
TLCA# 19547
Thanks for the info, now I'm just waiting for approval to post over on the cascade forum. I'll probably link it here since I plan on keeping this my main thread. I'll plan on showing up at the meeting and shaking a few hands. And I definitely want to meet the other 4bt swapper. I've got ideas for the motor mounts and AC unit for the 4bt but it'd sure be nice to see one set up already. I also keep my eyes glued on the 4btswaps forum. Good info on this engine over there and that's where I've been getting my engine specific ideas.
Old 06-13-07, 11:55 AM   #15 (permalink)
TLCA# 16127
Cool... we'll see ya then!
Old 06-13-07, 12:48 PM   #16 (permalink)
boots4's Avatar
TLCA# 19547
OK so I've got a little more time to post pics. Lets get to some engine fun.
Here's what I brought home just two months ago. It started right up and was very close to my place. I had bid on a few on dovebid.com but did not have any luck and the prices seemed to be inflated at the time because now the vans in the NorthWest are going for much cheaper. If it's less than $3000 grand in the Northwest I think it is a good deal, at least from what I've seen for the last 8 months.
I found this one on portland's craigslist and was only the second one I'd seen since I'd been searching. Poor guy, he bought it to do a swap, found the jeep he wanted to put it in, went on vacation, came back and the jeep was stolen! So that pushed him far enough to decide to move to arizona where it didn't rain as much. So lucky for me he was selling all his stuff and that's how I picked up this one. The other lucky thing is that he neglected to state that this was the intercooled version! More power, better EGTs! Although I beleive in stock form it will easily pull my cruiser around and I don't plan on turning up the fuel screw for more power right out of the gate. I'm sure I won't be able to resist tinkering later though.
It had some shelves and stuff in it that I had to take out before I could start cutting away.
then I started going to town
more cutting
looks like the dude got stuck in the mud a couple of times. underneath was covered with caked-on mud.
that's how much I've cut off up to now. it was fun driving around the yard like this.
yanked the seat so moving it around became a balancing act pushing on the gas and brake and cranking on that steering wheel. This one did not have power steering but was easier once a lot of the body was gone.
then I drove it up to the concrete under it's own power for the last time to pull the engine.
the hoist just reached far enough to hook up. I ended up cutting that crossbrace by the tranny to make it easier since the intake elbow was hitting the top of the cowl. Many have pulled this out of an uncut van but I'm borrowing that hoist so I ended up cutting stuff first before I could get it to my place. It sure is nice when you've got some decent equipement for the job.
that's me getting some arm action on (pumping the hoist). That's why I'm called boots because I wear those things wrenching and wheeling. I'll have to get new ones soon since they are almost warn through the rubber.
Once it was up high enough it twisted inline with the hoist.
I pulled it around the front and in the shade. It's barely touching the tranny pan but nothing else. If for some reason it decided to fall I didn't want it to fall very far. I didn't have any problems but didn't mind being cautions with the heart of my engine transplant.
still have parts in there I'm going to use
I separated the tranny from the engine on the ground and then hung the engine on a stand and taped up all the openings. It was greasy so I soaked it with engine cleaner and rinsed it with my pressure washer. I sure enjoy having that pressure washer.
other side.
here's a quick shot of it a little cleaner
the idea for a larger gas tank starts here. This is the stepvan's tank. I think it's 30 plus gallons but don't know the exact amount yet, maybe someone seeing this does.
and use these crossmembers to mount it to the cruiser. I've seen tanks mounted to the body and to the frame. The cruiser is originally mounted to the body so I don't think it will be a problem to attach it to the frame. The crossmembers are shorter so I will have to lengthen them but that shouldn't be a problem. That is a 14 bolt and I was considering using it and was torn on that for a while, but I decided to run the cruiser axle instead. Running the 14 bolt I would have to run a centered Tcase, deal with the lug pattern, the width difference (I'm sticking with my FJ60 front), all of which can be solved but time and money play a part. If I snap a shaft I can always upgrade. Plus I like the offcentered diffs. If you have to plow with the front a path is already made for the rear.
driveshaft and exhaust from the stepvan
OK, I'm taking a break for now and returning to "work."
Old 06-13-07, 12:59 PM   #17 (permalink)
TLCA# 16127
sweet!
Old 06-13-07, 02:59 PM   #18 (permalink)
incogrhino's Avatar
TLCA# 16350
way good thread, keep it coming.
Drafting the big bricks with my little brick
78'&80'fj40'&a83'fj60
Great Lakes Land Cruisers
incogrhino is offline   Reply With Quote
Old 06-13-07, 06:59 PM   #19 (permalink)
warpdriv's Avatar
COOL!!!! I'm looking for a 4bt van for mine. Go over to http://4btswaps.com/forum/index.php There are some cruiserheads over there. Keep the write and pics coming...
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
warpdriv is offline   Reply With Quote
Old 06-13-07, 07:48 PM   #20 (permalink)
boots4's Avatar
TLCA# 19547
Yeah, 4btswaps is a great place. Once I got the diesel bug I read just about every thread on that site! Great stuff over there. This is definitely the place for cruisers though, can't beat MUD!
Old 06-13-07, 07:49 PM   #21 (permalink)
boots4's Avatar
TLCA# 19547
BTW, dovebid.com had some super cheap vans in texas last month.
Old 06-13-07, 09:46 PM   #22 (permalink)
Doing a nearly identical swap just an NV4500 instead. Very cool project.
CRZA1 is offline   Reply With Quote
Old 06-14-07, 07:29 AM   #23 (permalink)
warpdriv's Avatar
Yea, I have been trolling dovebid. A lot of what they auction is jacked up. Like you, I want to be able to drive the van home. Then I know the motor is good. I'm also looking for one with power steering. Given that combo, it leaves my choices low. I'm patient though.
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
www.lslc.org/austin
Old 06-14-07, 08:00 AM   #24 (permalink)
boots4's Avatar
TLCA# 19547
You'll definitely find one then if you are patient. My van was funny because it was intercooled, had hyrdoboost (which I'll be using), but didn't have power steering. Plus is has a mechanical fan. The only reason I could come up with the mech. fan was that it provided at least some kind of airflow for the intercooler. I'm probably going to use a contour elec. fan and see if I can wire one side constantly on low to provide airflow for the intercooler.
Old 06-14-07, 08:59 AM   #25 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
Note to self:
Never let Boot4 pull one of my engines. If he starts at the rear bumper it's going down hill from there. LOL!
Nice build. To agressive for me but I'm glad to watch.
more cutting
other side.
Beagle Chariot
1962 FJ40
1964 FJ 40
1976 FJ 40
SPEN Trailer
Old 06-14-07, 09:03 AM   #26 (permalink)
what he said
Mace's Avatar
TLCA# Something
I know a friend in Redding with a 4bt Bread van she might sell..
My Myspace
Old 06-14-07, 09:06 AM   #27 (permalink)
redcorn's Avatar
Right on!
I am drooling over your build and have the same plan in mind for mine
No cruisers left behind, they all deserve a good home
BIG WAGONS RULE
http://forum.ih8mud.com/60-series-wa...orns-turd.html
redcorn is offline   Reply With Quote
Old 06-14-07, 09:07 AM   #28 (permalink)
boots4's Avatar
TLCA# 19547
I've been searching for a used np203 and found one locally last night that I picked up after work for only $40. There was a free one but it was a ford case and I read that those aren't compatible with the GM trannies. In order to mate the 203 to my 4L80 I'll need to do two things:
1. change out the input shaft to a 32 spline. this one was behind a turbo350 tranny and it is only 27 spline. The 203 behind the turbo400 has a 32 pline input but the junkyards wanted $300 for them. It will be cheaper to buy a 32 spline input shaft and swap it out myself. I've found some online and am still looking
2. redrill the bolt pattern and tap in new threads. Should be simple enough. Once I pick up my tranny tomorrow I'll be able to study that a little better.
No pics of this stuff yet but there will be, so on with the catch-up pics.
I'll finish off the stepvan stuff and then get back to the cruiser.
Those are the stupid-expensive motor mounts that I won't be using. I've seen prices of $200 plus used each to $800 plus each from the cummins dealer. I hope that was just web-inflation but even a motor mount costing $100 bucks is too much.
the turbo 400 that came with the stepvan. got someone just "looking" at it tonight.
I started painting the gas tank with rustbullet but I ran out. I just got some more this week so that could be a work night project.
here is the turbo on the 4bt. It's a holset wH1c which from the literature I've read says it's wastegated and has the 12cm turbine housing.
yup, there's the wastegate actuator
a turbo is basically two parts connected together. the turbine (exhaust side that gets the power) and the compressor (the part that does the work/boost). Interchanging these two parts can result in different boost levels at different loaded rpms. You can tune this to what you intend to do with your engine i.e towing, drag strip, etc. Anyways this is the compressor side and I have been getting some smoke due to oil being pulled past the seals. This can happen because of a dirty air filter or excessinve idling. I'm new to diesels so I did go out and start a lot it just to here the clatter and smell the diesel. Getting the diesel bug probably is some kind of sickness!
I checked the shaft for play and while I do have a little, I think I'm still in the normal range. For now I cleaned it up and am going to run it to get the cruiser on the road quicker. Pulling the turbo while in the truck shouldn't be too bad so I'll do a rebuild in the near future. This is the compressor housing.
I pulled some stuff off the front so I can get in and address the KDP (killer dowel pin, this can come loose and cause havoc). The engine has obviouly been repainted. I'm not sure if that means its had an overhaul or not. It starts right up and ran great getting it home so I plan on looking at some other key replacement parts and run it.
Old 06-14-07, 09:30 AM   #29 (permalink)
too tall's Avatar
lookin' good
Looks great so far . Keep posting !
1977 fj40 All Beat Up ... But Still going strong !
1993 80 series
too tall is offline   Reply With Quote
Old 06-14-07, 01:38 PM   #30 (permalink)
Great build-up thread! Keep us posted on the progress and photos.
Cheers!
Rigpig is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
