some h55f and split case tech
For those nutty like me, Toyota has a 1/4-19 BSPT plug that fits perfectly into the 5th hole on h55 swaps.
just to make a very small contribution to this great thread. Im in the process of rebuilding my 3rd split case this month and recently came across something I haven't came across before. Apparently there is a later model rear bearing retainer that actually takes a larger seal. Thanks Georg for the heads up and here is a photo of the part number.
To add some additional images to this thread, below is a photo of 3 of the input shafts that Toyota offered for the H55f transmission:
Left: F, 2F, 3F, H, 2H, 12HT type H55 input shaft.
Middle: HZ type H55 input shaft
Right: B, 2B, 3B, 13BT type H55 input shaft
I've included what I've found through reading on the forum. The photo above also shows the late iteration of the H55 input shafts with the bigger bearing and the late type front bearing retainer. Please correct me if I have listed them wrong.
For reference:
HZ type H55 input shaft part number:
Late 3B type H55 input shaft part number:
Hope this helps,
-Alberto
Is this thread still active ? Need some advice on input shafts as I cannot mate my gearbox to my engine as there is an inch of space left between the bell housing and engine when the input shaft spindle has seated on the pilot bearing.
Please help this is urgent thanks
Try posting a new thread - include "Real Time Help Needed" and a specific question. It would help to provide details on which engine and transmission you're dealing with. You'll get some responses.
I see this is your first post, good luck with your build. @orangefj45 is the best person to help.
I’ve mentioned him here so he will get an alert. But as above,
what engine to which transmission are you dealing with? Be year specific too, there are a lot
of variations.
Yes I’ll do that thanks
of variations.
@cruiserpilot
I have a 1992 PZJ75 and so happens is that the gearbox has been modified by an early owner where he’s stuck a Adapter plate between the gearbox and bell housing, I reckon his gearbox was bugged and he found a replacement but it wasn’t the right one so he had to use that gearbox. However I did manage to identify the gearbox and it’s a H55F. The original gearbox that was mated to the 1PZ by Toyota was a R151F.
Recently I bought a donor BJ75, now even this truck has had a fair bit of modifications done to the drivetrain. It had a 1HZ mated to a 4 Speed which I reckon is the H42F. The BJ75 had this drivetrain setup perfectly with no adapter plates or spacers.
So what I’ve done now is
-Removed adapter plate and bell housing from the H55F
-Used the bell housing from the H42F that was mated to the 1Hz no dramas
-bolted above said bell housing to the H55F
-Tried mating the H55F and 1HZ but there seems to be a gap of about 1/2 inches Between the Bellhousing and engine. The input shaft is seated right into the pilot bearing.
I’ve gotten as detailed as possible and I’ll attach pictures once I try it again.
But what could it be? A longer Bellhousing ? A shorter input shaft as the OP had said?
My 75 is sitting in my shop crying ahahah so any help would be appreciated thanks beforehand
Its beyond my knowledge. This thread has pics of different variations of transmissions
I think you would be better to start a new thread and post pictures of what you have.
Lots of times someone will see at a glance what is going on.
Yes it’s a bit too much to grasp at once
Anyway I have a new thread up
How long did you all wait to change your oil after the initial fill on a new h55f and rebuilt split case? I went 3,000 before I swapped fluid the first time.
That's about right.
Good to know. How long should I run this 50w mobil one synthetic in the trans and t case? I’ve got 20,000 on the current fluid.
I have an early H55F (6/1985) in my FJ62 and I am struggling to source a new layshaft (33421-36040) here in Australia.
I have a couple of questions, what is the difference between the early layshaft (33421-36040) and the later, post 10/1985, layshaft (33421-60060)? Are they interchangeable? If they are not directly interchangeable can a later one be used in an early box if I change some other parts (at 10/1985 I think the reverse idler gear and input shaft changed with the layshaft), or is there something fundamental that will mean this is not possible?
If this thIs not the right spot for discussion on this I did start the thread below before I came across this thread.
Early vs late H55F lay (or counter) shaft
Thanks wobson
I'm a bit nervous now!! I have a 87 FJ60. I bought a H55 new from Toyota My Tcase is the 38mm. I got the rebuild kit for the Tcase,new clutch,rear main, new transmission mount. Am I good with the output shaft or.......?
Part number for my H55. 33030-60450
Have you tried Terrain Tamer?
I certainly have, I called them and they told me that they (and Toyota) no longer manufacture the older pre 10/1985 lay shaft. Below is an extract from their site only showing the newer one...
Looking at Transmission Gear (Mtm) for 1984 - 1987 Toyota LAND CRUISER FJ62 | General sales region, , 18027100-936735 and tracing all the parts that changed in 10/1985 I can't immediately see what the difference between the layshafts would be. This is what I am thinking:
  • All the gears/bearing on the main shaft are the same, therefore gear profile of layshaft is the same and the position of the drive gears along the layshaft are the same.
  • All bearings/nuts/snap rings/5th gear parts on the layshaft are the same, therefore since it is the same 5th gear assembly, the layshaft is the same dimension below the mainshaft in the gearbox housing, and then all the other drive gears (excluding reverse) on the layshaft would have the same number of teeth.
  • The input shaft/bearing/seal/retainer changed, therefore, if this change is more than just a seal/bearing change, there may be a change on the layshaft input gear (teeth profile, teeth numbers, position along the shaft of the gear etc) or the length that the layshaft protrudes into the input shaft retainer after the snap ring? Can anyone confirm the differences in the new or old input shaft (part numbers in image below)?
  • Reverse idler gear changed, now the teeth profile and position along the mainshaft must be the same as it mates with the same reverse gear on the mainshaft, which would imply the layshaft reverse has the same teeth profile and position. Now, I know the gearbox housing changed at this time too, in the new housing is the reverse idler in the same relative position to both the mainshaft and layshaft, if it is then I can confirm that they are the same ratios and same number of teeth on the layshaft reverse. Can anyone confirm this?
Thanks all, after typing all this what I might do is take a photo with some dimensions and count the number of teeth on reverse and input of the early style layshaft and post it here, if someone could do the same with the new one that would be greatly appreciated!
Cheers wobson
