- Joined
- Jun 21, 2011
- Threads
- 225
- Messages
- 21,003
- Location
- Redding, California
- Website
- trail-tailor.com
And the retractors have different mounts right?
C,
Its been so long since I've looked I can't remember, but believe you are correct.
J
Yeah someone should check out the rear seatbelt configuration in 78 series wagons and 4-door 79 series. Maybe even the rear 80 series belts will work?Yes, was wondering if the same set could fit in the back seat or if another 70 series kit would work as a retrofit.
Thought length measurements of an OEM rear set to compare to the front retractable belts listed above would be a starting point.
I just have the lap belts. Our 62 was born a few months too early to get the shoulder belts. I may try the non-retractable OEM option that $OR lists as that is a bolt in solution.
I have both new 60 fronts and rears, I'll check. IIRC the rears are a bit shorter.
J
As far as I know, no one has demonstrated using new OEM toyota parts for the rear seatbelts from another cruiser. The original 60 series parts are long discontinued from Toyota and the only new sets I know of would have to be pried from @reevesci 's iron clad grip. hahahaha. I would be very interested to see if the rear belt assemblies from an 80 series would work, or another 70 series. Someone should explore this.......anybody got a parts list for replacing the rear belts with OEM parts still available, for retractable belts and the center lap belt. a list of numbers would be awesome.
thanks
Hey,
I know this is a old thread but just wondering if anyone found any details on a replacement for the rear seat lap belts on a 1982 fj60? Hope someone came across a bolt in that is still available ......
Thanks
The 79 series belts I posted?
A quick search on amayama shows one shoulder belt for $130, the other not for sale in the US. Maybe try another overseas website like megazip, or I think there is a guy in the classified section offering to send parts from Japan. Also I have seen references to this source for parts from Japan: David Stedman from Japan4X4.comyes.
