Builds My Tucson 40's (14 Viewers)
Front end is back together. Finished up a ton of small loose ends. Brakes are bleed and still need some adjustment. Trailering it over to get the exhaust done tomorrow morning. Hope I can dodge the rain. :doh:
I moved it in and out of the garage for the first time under it's own power.:banana:
Here is a part we need Toyota to reproduced.
If I knew I was going end up with a few 40s when I bought this one I would have purchased a few of them. Helps with the desert heat. Miss not.having a.open 40 to drive. Probably move it over to my 73 it I ever get it runnimg. Luckily it survived a mishap I had in my 68. The muffler not so much.
Never seen one of those heat shields. Does not look hard to reproduce.
My exhaust turned out pretty good. Nice and quiet too. I forgot to take pix when it was in the air on the rack. So, here's some crappy garage pix.
With that muffler would consider one of the 75-78 heat shields.
Appears the first piece of exhaust pipe is getting harder to find. I know still have one that runs under the skid plate. Probably have a used aftermarket that runs above.the skid plate.
Personally I don't like the stock exhaust. I get 2 1/4 and a cheap muffler and it works great. 2 hrs and $375 and its done.
I adjusted the brakes and went up and down the block. I did a series of fast stops to help burn in the brakes. So far so good.
Engines runs good and trans shifts well. Still a few items to do but overall.......its rolling.
Painted the hood this morning. Bummer is a bunch of nats flew in and got stuck. :confused:
I have driven up and down the block a few times. It's not registered yet and I just applied for insurance this morning. It seems good so far. :grinpimp:
Despite the hood turning out like crap, I installed it on the 40. Still need to align all the front sheet metal though.
Overall it's almost done , but some gremlins have been kicking my butt. I am taking the day off tomorrow and going wheeling.
There are 2 hangers for the whole set up. The rear hanger uses the stock location and the one in front of the muffler is hung off a flange of the floor support. Hope that makes sense.
Man, this is right up there with the red one you did a couple years back and I had the privilege of seeing. Love how quick and efficient you move on these... and the attention to details.
