Mike's 1978 FJ40 Build (2 Viewers)
Please do Georg, my Saginaw pump is not aligned so I would like to compare to an oem setup
Matt, You most likely have the wrong pulley on it.
Your Saginaw may benefit from this pulley:
1423932597758-jpg.1031344
1423932638786-jpg.1031345
You might want to check my pulley issues thread here
My Saginaw doesn't have a keyed shaft. I am using a Volvo pulley and mine is actually offset in the forward direction using the jt outfitters bracket. Oh well
Today I installed the new PS pulley (that Georg @orangefj45 sent me) and it looks great and perfectly aligned with the other engine pulleys.
Pulley installed
full
Belt installed and now has proper clearance off cooling hose
full
Belt aligned perfectly
full
Both belts living in harmony
full
Next step is to remove the fender to remove the old gear box and install the new mounting pedestal and PS gear box.
Good to see how that worked out, and good that Georg willingly worked with you to find the correct solution.
By the way, which part of the great Pacific Northwet do you call home?
Don
Nice work! What is your build date? I noticed you have the side window defrosters, which I think came later in '78.
My '78 has a 09/77 build date.
Pablo, I have a Federal model 12/77 build date and it has the side defrosters...not sure when they started, though.
Wow, I just missed out!
I love my '78, but it was very difficult to add PS to mine, as my block was not tapped for the PS pump bracket like Mike's...
The nickel trick.
I did the penny rebuilt on the relay rod/Pittman arm ball housing, the pennies really didn't work that well so I upgraded to nickels and worked great. Here are a few pics.
full
full
full
full
full
full
full
Looking good Mike. Will PM you on my fuel vent stuff, thanks bud!!!
Thanks Tom! Let me know how things are coming along.
Finished the rear brake proportioning valve install
full
Painted the PS gear box
full
full
full
Painted heat shield with high temp silver paint this should help keep the PS hoses cooler
full
Painted PS box with high temp black paint
full
Installed the PS box and associated plumbing
full
Insulated PS high pressure hose to protect from exhaust manifold heat
full
Tomorrow I'll ad the PS fluid and should ready for a road trip to GA.
Amazing work. Just have to ask, how did you get your air pump looking like that? Was it taken apart and rebuilt? Where did you get the sticker?
Thanks!
I didn't need to rebuild the air pump as it runs perfectly, however, I did clean and paint, the sticker is original and taped it for paint so it looks brand new.
Just got new tires for my rig
full
GY Duratracs
full
Now waiting for 5 steelies to arrive from @beno
...and five hub caps.
I received my steelies and hub caps from @beno, several weeks ago.
Excellent person to deal with and excellent product!
full
