Builds Fly By Night (15 Viewers)
I don’t have any experience with that unit, but I use the OBDLink MXii+. I run a basically stock cam/tune- just deleted vats, etc. Mostly I use it to supplement my stock gauges. Never had a single problem with it. As the name implies it will scan for CEL, I use this more in other vehicles.
Thanks @archie73 ! This is what I was fishing for. I’ll check out that MXii 👍🏼
6 year build anniversary just a few days ago.
😓 Hard to believe!
180 pages of thread bear proof of this, but I have a folder in my photographs on my phone titled “FJ55 Build” that has over 2,300 pics.
Any time I start scrolling through them it starts becoming overwhelming and then I just have to stop.
Keep looking forward!
Onward!!!
You can do IT!!!!😘
Ordered a radiator from Mosley, but I must have screwed up the order (despite making a note in the comment section that this would be for an LS conversion) and ended up getting what appears to be a stock replacement.
No steam port, and inlet/outlet being of factory size and placement. Will probably get ahold of them Monday to try to arrange an exchange, unless… someone is in need?
Power steering and hydroboost plumbing.
Emulated Scrappy’s reservoir position, but wanted to just try welding the bracket to the alt/ps pump mount. The hard part was making the AN10 hose from the res to the pump, which in this incarnation is a 150° barbed m on the res, and a 45° barb on the pump.
The pressure lines are 6M2T crimped fitting hoses. The supply to the pump and all the return lines are textile reinforced high temp hose, with all but one (on the cooler) terminating on a 3/8” JIC to 3/8” barb 90° fitting.
Sum bitch, that's a lot of plumbing...
