FJ60 Ecoboost swap? Is it possible?
Is it possible?
  • Yes
    Votes: 13 81.3%
  • No
    Votes: 1 6.3%
  • No, but that would be insanely cool
    Votes: 2 12.5%
  • Total voters
    16
Outer Banks, North Carolina
I have an '85 FJ60 with a 2F and im just wondering if an 2.7 or 3.5 ecoboost swap is even possible. The dimensions say it will fit, but im not sure, with a 6 or 10 speed behind it. If not, any other non-v8 options that are unique?
I do not understand how or why this would not be possible. Anything a f150 can do a fj60/can do better. If people fit coyote engines in fj60 why could a 3.5 not fit?
If you want something unique try a twin turbo 4.2 i6 vortec or a 3.0 i6 duramax. Or a 4.5l power stroke. 8.1 vortec would be cool too.
But complete low mile take outs including transmission and computers for a 3.5 echo boost are around $5000 so it would probably be the cheapest swap.
All of those engines are cool but you have to keep in mind the weight factor. I don't think a power stroke or a dura max would go nicely due to their weight. The eco boost might be a good fit.
yes, they bolt right in
2f engine is about 600-800lbs
4.5l power stroke v6 835lbs dry.
3.0l duramax should weight about the same as a 6de1 dmax v6 which if a sabb 9 can handle its weight I would think a fj60 could.
OEM heavy up front Chevy springs in back all is good.
Ford sells the harness for hotrods to put the eco boost to a standard transmission. which I think you could find a transmission that can be set up with a transfer case. I think it's a tremac and you need this .
Lots of the ground work has been with chevy engines so people go that way.
But I really like eco boost engines. I drive a 7200 work van with a 3.5 ecoboost. It has great MPG and endless low grunt torque. It's the closest gas version of a diesel. lol. It's direct injected and turbo charged.It gets it's power at low RPM. SO it hauls you around quite well. I have felt it would be a good engine in 60 series.
I would look at a take out engine from a wreaking yard, but go with the standard trans and crate harness.
All great engines, why don't we ever see them in the conversions? I think a power stroke 60 would be sweet, or even a dura max? I always figured they would be to heavy.
Because the 3l duramax USA version inline 6 is not released yet. The big v8 duramax engines are quite heavy/expensive to use in a fj60.
The 7.3 l powerstoke is way way too big but the small 4.5l should fit fine again a rare engine because only used a few years in certain types of delivery vans.
Isuzu brand of dmax (not the USA duramax) type engines are also hard yo get in USA and cost would be the limiting factor.
The banks 5.0l Cummins is nice to look at if the op wants something unique.
The biggest problem is the smaller aftermarket as compared to an LS platform. That being said, not a bad idea and I would definitely read the build thread.
I like the idea. Should make a FJ60 scoot pretty good.
If a Cummins 6BT diesel can fit, I’d say it’s possible.
This swap sounds spendy, they all are, unless you have sourced a donor.
You May find you still don’t get that great of mpg’s.
I’ve got a few friends that dropped v8 trucks for the ecoboost, and none felt it was worth it. The mileage was lower than expected and they had bugging tune issues like the inter coolers freezing up.
I’d rather have a pushrod v8 in one of these.
I would recommend doing a few repairs on eco boost engines before considering swapping one in. A LS motor is comparable to a 2f in its simplicity to work on if not easier in my opinion. Ive seen some low mile head gasket issues on eco boost engines. As in less than 70k miles. I work on very few eco boost engines however, so talking to a ford mechanic would net a better review of the motors.
Alright, i have a question .... who gives a f*** about mileage when we drive around in these old bricks?
Don't worry, no one who starts one of these engine swap threads ever actually does the swap.
15x40=600
20x40=800
If one could get a fully loaded overland truck to get 20mpg would make a difference if the next refill station was 800 miles away. Assuming one only has 20 gallons of reserve fuel. If was a daily driver filling up once every 4 weeks vs once every three weeks would make budgeting fuel easier since one would be able to count on one tank per paycheck. I never understood why when people are planing out engine swaps people planning and trying to find an engine that provides a good ratio of torque/hp/mpg others are always against the idea of it being a possibility. Of course no one denies that aerodynamics is always an issue with 60 series land cruisers. I for one applaud anyone who is willing to research and implement a modern engine that gives the best overall performance one could.
Most engine swaps are similar budgets some more savvy people can get away with cheaper but most are withing a few thousand dollars. Unless going super extreme. A p400 engine would be pretty neat and could probably be a great engine for a 60 series but cost would be around 15,000$ for just engine and parts needed and at the end of the day it is still an old tired engine that isn't a great choice these days. A built 4.2 i6 vortec is probably one of the better modern engines for our trucks but again cost the limiting factor as most will need to be rebuilt and after upgrades and twin turbo setups with intercoolers and after coolers the cost would be high again.
The best modern engine would be from a 3.0l duramax i6 engine but that would require buying a 2019 pickup stripping engine and transmission and planting it in a 60 which would probably cost more than most people are willing to spend. So we need to be vigilant and watch the insurance auctions to find when someone totals one.
One more engine if you wanted to keep things toyota is a 2JZ-GTE . That would be pretty unique. 378 hp 361 tq
