Builds DRANGED's GX470 build/ownership thread (3 Viewers)
Prepping. . . .
Ugh. . . . :bang:
now this process.
View attachment 2411508View attachment 2411509
fob still locks and unlocks and key starts engine. So I'll try a case, cut the blade, and swap the guts ...
Get a YotaMD key cover. Nice upgrade from OEM
whoa, those are rad.
Even just the upgrade would add strength... Although 13 years wasn't a bad run for stock. But doubling that (as my lifetime car) wouldn't be a bad investment... 🤔
*edit: NM, I see how it's a component system, not just add the titanium layer to a stock fob.
Well....tickticktick
This became apparent yesterday. . . . Cracked exhaust mani. :bang:
Yeah, its the powder 3d print cover, plus titanium plates. You can re-use your key blade and the remote part, or get a new key blade VIN cut at the dealer for $25-35. I love mine, you can even color match to the car if you want.
Fob guts swapped to new fob shell, I couldn't see a way to swap the blade so now to get this new blank cut and ill be golden.
Okay!
So, dead key case 8/21/20...
Ordered these blank fobs (2 for $14ish shipped): 2 New Replacement Key Case Shell Keyless Remote Fob Uncut Blade Lexus Gold Logo | eBay
Guts (transponder) swapped stright over. The stock key's blade is molded into the plastic, so I could'n swap the blade:
And with a neighbor's time... SUCCESS!!!
New key running the GX 8/29/20! 🤯
So a Lexus (probably aftermarket housing) transpondered key, cut and working again, for.... Not much!!!!
Gary is a good guy, and if you're ever hosed with key needs in Moab, call on him (recognize that he has this business and like 2 other jobs too though ;)!!!
finally got one...
Having dealer diagnose per codes, while it's in for the cracked exhaust mani... They just called me back reminding me it'll probably take 8 studs (i expected this and suggested that be in the initial quote) and said they'd save me labor on the code and experience suggests its a charcoal canister (of coarse)...
watching that bill climb part-by-part. :confused:
B U T it's getting done. I've been clearing those codes for like a year and a half.... 🙄😒
Only four things that cause this (in order of ease): gas cap, vent plugged, charcoal canister, purge valve.
I think I looked into replacing the canister a while ago... Sort of a job, but comparably relatively easy.
Thanks @Vlad , this is a perfect"order of events" checklist.
I PMed mine before I put in the aux tank as it is now above 290# of fuel and steel haha
Exhaust mani repair completed!
SUPER quiet again! I hadn't realized the slow increase in tictictic, until it finally let loose!
Hindsight, always 20/20: I had noticed my 07 was a little tickier than @Lifted's 05 (similar mileage) when we fiddled with his bumper last summer.... I recall thinking, WTF, why it is making that noise? his older 2UZ is quieter than mine!... 😝
So my PAX exhaust manifold failed in the tube bend upstream of the cat, NOT at any weld. But the failure was a nearly circumferential crack. I was surprised to learn the manifold in this car is NOT cast but welded tube. interesting.
pix of gasket for kicks too... hmm.
I replaced the 8 studs too (as I expected), but sadly THOSE didn't get returned in the box with the other broken bits I asked for :(
At any rate, she purrrs again!!
Oh, and I had them do my 5-tire rotation while it was there (46K miles on these KO2s, and they have 10/32 tread remaining), since I was due and was returning my 6 ton jack stands during this same drop-off trip (HF is 2+ hours away, as is the closest Yota dealer) and therefore lost the means for "safe" vehicle support at home ;)
So I turned those stands' in-store credit, plus a $40 off coupon into a tool cabinet (which gets surprisingly good reviews) for $250 :)
perfect fit (thankfully) for my wife to retrieve after the GX pick-up (Thanks honey!!) 😝👍
Jeez! This thing eats KDSS RSB bushings! 😲
Maybe I'm doing it wrong when I install them... 🤔
*EDIT* adding PN:
G7y_SLbj_4CV5M8JungKq7jhaB8I6InFZDJasgFZakiBg0MYtP0mZi4MNH4kKutjUdra3FXMbwnB4hhIweHQca53cyDsSEU_jCgOE3wKWVJYmykm3rV3VwwsqdX37o4mUtwXxMGXnWiIuxZO8PVDS_aFFOhddlr4U9rSMJeqZaCD9-dDk-VcVIbeJj0nlWc-a8tKIQHSNGjcKJTu8nVDP2mHTui44fEA0-s4Tg1AqGjHNx32A84fXEypNz2rFMBQ85BhjH5PwZppn7iRqUpCiCuHGMr_gmf6tvGO3xWaw2D-tb40TrxrPuokZvnQxuqCsus_5LMoLfEmOOeFJ85IY8j-AF9xl4daDEbBIPtRkBqzyu0YVhX3uk_bwp8xJGEFHlMPP-rvZcs652gwlosfP1By1bCYNjedzudOJx49DjMQt1NXv8kqQhbLFNTBw8Jp7WHg5iDfmPBz8TNr6KrydKG5Qn-5LiIhHG12lB2OPyHe15wOeAFWHdvDKqJUxmkuu1KjpnXJZ7t_f5dF8nXDU0CWm6P09xn0L5GHDe82aBTHYedXKNeoJot5dUoA5JJOTFloDTsxbR5DOJwteRs1DgvXeXDA_uLWcDb3YQZf-fBl86jLiSdCe29kx7SxiVa1bxK90Zcdk1fYtTyxWyLyHoqr49OA11zYpwOEjIp7CSn6ldpZEchFNqNJc9DsWvSYmYnWWeIapLjLcbE1b1RPeovJDA=w1470-h828-no
How's the Cruiser doing?
Is it up for a White Rum trip?
Ooooooooo!! @MoaByte
Intriguing. 🤔
When? How many days?
How many in yer permit?
This does remind me, I have a trip report yet to file: We did a 4 night 5 day (sat-wed) before Thanksgiving.... 😎
I'm sure we got someone's cancelled dream trip.
Photo journal here
Cruiser's good. Sad from disuse....lack of driving and cold killed the battery yesterday.... 😤
View attachment 2432168 View attachment 2432169
View attachment 2432170View attachment 2432172
I’m thinking about buying that exact workbench. LOL Glad to see the box fit!
@MrTorgue
yeah, it's a good fit and super solid esp for the price point (I had a great coupon for it!!)
battery talk.
The interwebs suggests ar Quest has Die Hards now not Autocraft (rebadged same-same? 🤔
Replaced CQ Autocrap silver 27f (died in 3 years)... had 24 mo warranty (unknown if any prorated),
with Napa Legend Premium 24f with 24month free replacement and 84 month prorated warranty (and had a $20 mail-in rebate).
My NAPA doesn't have a 27f in legend premium, just legend which is only 18/72 and lower specs.
