- Joined
- Jul 22, 2012
- Threads
- 578
- Messages
- 16,285
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
- Thread starter
- #461
Now that we are on the topic, here's some NV4500 tech.
There are three versions of this transmission you need to know about:
1. 92-95 Chevy
2. 96-up Chevy
3. 96-up Dodge
#1 will be referred to "Early Chevy" and #2 will be referred to as "Late Chevy" for clarity.
Early Chevy has a 6:34:1 first gear. It has exactly the same input shaft and front bearing retainer dimensions as an SM465, the one people have bolting up to Toyota F-Series motors for decades. The only difference between the front face on an Early NV and an SM465 is the bolt pattern on the main case. If they were the same I would be able to just use a 3-speed bellhousing and this would be easy. Not the case unfortunately. Two options that I can think of to use an Early Chevy NV:
1. Drill the transmission case for the SM465 pattern (This has been done before, however it was in a SM465-NV4500 swap where they used a Chevy bellhousing. When you drill the case there isn't enough room to bolt bolts from the outside, so you would bolt the bellhousing to the transmission then the bellhousing to the engine. This won't work with the F-Series bellhousing as the bellhousing has to go on before the flywheel)
2. Make a plate to bolt a Chevy bellhousing to the 3FE. The only problems I see with this plan are that then the input shaft would be too short by the length of the adapter plate. And I would like to keep all Toyota clutch components besides the clutch disc.
I think the answer will be a creative to solution to method #1. I would like to use the Early Chevy for the lower first, although any version will be an improvement over H41/H55f.
1. 92-95 Chevy
2. 96-up Chevy
3. 96-up Dodge
