TCEd
Visual weld inspection tips
What rust? Rustfree sandblasted frame.@-MaTTi- grind the rust off before you weld next time
Do the rear spring leafs apply any force on the rear end?My take is that what you are tying into looks sketchy. Way too much pitting back there. Not that it needs a whole lot of strength to hold a stock axle and tire but at least I would have run the scab plate further up the frame. As long as your gas tank isn't in the back you will be fine. The tub doesn't really have a lot of weight on the rear. In an accident where you get rear ended the new stuff will hold up fine. The frame above the rear axle is going to fold from the shock mount back. Not a huge issue.
What plate? Please tell more about the problems. I can´t see any.that plate on the outside of frame is wrong in so many ways
I just read this article.. Leaf Springs - an overview | ScienceDirect TopicsOnly if you sit on them.
Check in the comments on the Aqualu website.It may save time and money to just get a new frame.
#4190 1968-1978 FJ40 Frame
Fits 1968-1978 FJ40 Land Cruisers Weight Approximately 274 lbs without spring brackets or shock towers Approximately 313 lbs with spring brackets or shock towers Wheelbase 90" Finish 4 x 2 mandrel...www.hardbody4x4.com
They said ...
Each half of the leaf spring acts as a cantilever carrying half of the total load.
The bending load applied to the leaf spring center varies from a maximum of 6000 N to a minimum of 1500 N.
Because the problem has been simplified as stated previously, these loads are reduced by half at each end.
Fmax=3000NFmin=750N
If N convert to lb force... form 680 to 170 lb force on each end ?
I actually not worry about load, I interesting how much force will apply when rear wheals hit some bump for example..?
Don't be sorry, I like when people have a sense of humorSorry SergP, I was just poking fun at the wording of your question. But addressing your question, I think all that’s important is that the frame be repaired in a way to be at least as strong as it was originally engineered and built.
Definitely. That’s not the frame’s most problematic point even if it’s weakened.Ynnodf you frame will be fine..
DEADSALT said:
@-MaTTi- grind the rust off before you weld next time.
* This is meant as a very helpful tip. Prep in welding is key. Clean shiny metal likes to be welded to clean shiny metal.
It was grinded where the support plate and welding is, not further. Inside was more pitted surface, so it was not 100% shiny.
